7mroadster Posted April 24, 2017 Share Posted April 24, 2017 Rather than waste potentially a couple of hours (almost) aimlessly looking for the brake pressure switch on my 2014 Birkin S3. Can some one tell me where it should be? It isn't on the rear master where most mass production switches are, so where? Thanks in advance. Link to comment Share on other sites More sharing options...
waltermitty Posted April 24, 2017 Share Posted April 24, 2017 It is under the differential at the junction of the rear brake lines. Link to comment Share on other sites More sharing options...
Tbox56 Posted April 24, 2017 Share Posted April 24, 2017 Under the rear diff is correct for the IRS cars. The live axle cars it is located on the axle side of the rear bulkhead, in the fitting where the steel brake line changes to rubber going to the axle. Tom Link to comment Share on other sites More sharing options...
7mroadster Posted April 25, 2017 Author Share Posted April 25, 2017 Under the rear diff is correct for the IRS cars. The live axle cars it is located on the axle side of the rear bulkhead, in the fitting where the steel brake line changes to rubber going to the axle. Tom Thanks for the responses. Link to comment Share on other sites More sharing options...
