slngsht Posted July 28, 2007 Posted July 28, 2007 I REALLY should avoid looking at things like this Those numbers are at the wheels!! normally aspirated, all motor - direct bolt-in for me :willy: Best part is the FLATNESS of the torque curve... YUM [edit: this is NOT from my car, but it could be ] http://www.usa7s.com/aspnetforum/upload/2041506062_Dyno07-19-06.jpg
solder_guy Posted July 29, 2007 Posted July 29, 2007 I REALLY should avoid looking at things like this Yeah .. Exactly how strong are your motor mounts ?? :crazy: Rob
slngsht Posted July 29, 2007 Author Posted July 29, 2007 not really sure but having a hell of a time finding out
BusaLoco Posted July 29, 2007 Posted July 29, 2007 Very Impressive Numbers, especially for a Se7en! WoW, and look at the weight...3,750 lbs!...That is a lot of ballast! BTW, what kind of LOCOST variant is a "Pontiac Trans Am"?
slngsht Posted July 29, 2007 Author Posted July 29, 2007 Very Impressive Numbers, especially for a Se7en! WoW, and look at the weight...3,750 lbs!...That is a lot of ballast! BTW, what kind of LOCOST variant is a "Pontiac Trans Am"? ah, you can ignore all that stuff... it's a direct bolt in for me, not one pound extra weight, with 2000 lbs less to push around than in the F body. I'm not quite ready for more power yet... just getting used to the current power level now. After I get totally used to slidin' her around, I may entertain something like this which still has serious top end, but better low end than what I'm currently running.
