I REALLY should avoid looking at things like this
Those numbers are at the wheels!! normally aspirated, all motor - direct bolt-in for me :willy:
Best part is the FLATNESS of the torque curve... YUM
[edit: this is NOT from my car, but it could be :D ]
http://www.usa7s.com/aspnetforum/upload/2041506062_Dyno07-19-06.jpg
Very Impressive Numbers, especially for a Se7en!
WoW, and look at the weight...3,750 lbs!...That is a lot of ballast!
BTW, what kind of LOCOST variant is a "Pontiac Trans Am"?:D
ah, you can ignore all that stuff... it's a direct bolt in for me, not one pound extra weight, with 2000 lbs less to push around than in the F body.
I'm not quite ready for more power yet... just getting used to the current power level now. After I get totally used to slidin' her around, I may entertain something like this which still has serious top end, but better low end than what I'm currently running.
