In the process of getting the drive train together on Birkin using Duratec 2.5. The steel shim over the aluminum flywheel is give me a fit as the hole don't quite like up but I think I have that licked. I looked down and realized I didn't have a pilot bearing in the rear of the crank as this engine came from an automatic car. Transmission is T9. I'm guessing that the Mazda F801-11-303, one used in early Miatas, is the one and there is a Mazda dealer down the street. Input?
Thanks for the information. The Ford D4ZZ-7600A, Mazda F801-11-303 cross to the National # FC-65354. Between the Ford, Mazda and bearing house, I ought to be able to get one tomorrow.
