FE07 Posted May 21, 2018 Posted May 21, 2018 Decided to get a jump on nutting and bolting my car for NJMP in July and discovered something loose I've never noted before. Thought I'd share it with the group as an FYI. Small recessed bolt at front lower shock mount to A arm. It's a 1/4" allen and mine was loose on 1 side. Not falling out but I've never seen it loose before and it would be easy to miss since it's recessed. So.......... add it to the list of things to check!! See you at the track, Jim A.
