General track use questions
BeagleGuy78
So tomorrow is the first day I will be driving the Seven on a track in anger! Have a gopro set up with remote mic that will hopefully provide decent enough sound to not be annoying.
I had a couple questions about tires/wheels. What torque should I put on the lugnuts for the wheels? I like to check these before every session and want to make sure I don't over/under torque them.
Also, I have Avon tires on 13" Apollo wheels, what would be a good target HOT tire pressure? What is a good cold starting point to achieve this hot pressure? I am thinking target 18psi hot and starting at 14-15psi and bleed off after every session as needed to keep 18psi?
Thanks
