Colorado7er Posted July 5, 2019 Posted July 5, 2019 Brand new OMP Formula Quadro steering wheel + shift knob set. Steering wheel is 250mm diameter, flat bottom, red suede. Super high quality -- suitable for formula cars as well as sprucing up and racer-a-fying Sevens. $200 shipped (CONUS) for both. http://www.usa7s.net/vb/attachment.php?attachmentid=15622&stc=1
Colorado7er Posted July 7, 2019 Author Posted July 7, 2019 I was asked, so to clarify: the knob is unthreaded and is a "fits all" design that uses grub screws to tighten the knob onto the gear lever shaft, and then the base ring screws onto the knob. So M8-M12 levers work no problem, as does the 3/8 UNC (found on most T9 levers) and thread pitch is no issue. http://www.usa7s.net/vb/attachment.php?attachmentid=15638&stc=1
