So this is comical. I took my car in for service at a local shop I’ve used in the past on 1/4/21. My punch list is (1) install new 6 point harnesses, (2) replace thermostat with one I provided, (3) replace radiator temp sensor and see if that makes the fan work, (4) tune 45 DCOE Weber carbs for my elevation, (5) address oil leak in joint in dry sump hose.
Harnesses installed but crotch strap omitted so I’ve got to take the seats out again. Thermostat was lost or thrown away rather than installed. Jets were changed on the Weber but they clearly weren’t tuned and the gas fumes are overwhelming. Oil leak was deemed not an issue and not addressed. ¯\_(ツ)_/¯
Anyway, I need someone to tune the Weber carbs. Does anyone have someone they can recommend in the Atlanta area?
