JohnK Posted September 1, 2007 Posted September 1, 2007 I have a complete engine and fuel system from a 2000 Ford Focus ZX3 M/T (the 2.0l DOHC 4-valve engine) that I would like to sell. I got this system to put into a Superformance S1 and to be able to experiment to see how much power I could get from it using an EEC Tuner. I wound up with a different Seven and engine system and would like to sell the engine system. I got a complete car from a local 'yard and dissected out everything that had to do with the engine and fuel systems. For example, I have the components for the PATS including the ignition key, the ECU, the complete (and undamaged) wiring harness and all the bits that went with it like clutch pedal switch and brake pedal switch, the MAF, air box and filter, i.e., the works. The engine includes the exh manifold, catalytic converter and flexible connector to the rest of the exhaust, the clutch and F/W and starter, and the water pump. The fuel tank was removed with pump intact along with the fuel pump controller (returnless fuel system) and all the plumbing connections. The fuel supply and evap lines were cut for removal. All other evap pieces included. Other than the fuel and evap lines and the connection from the wiring harness to the air bag controller, nothing else that was removed was cut. Because Ford connectors can be really difficult to get and can change in mid-model year, I went through all this trouble to ensure that everything needed by the engine and fuel systems with respect to engine management control was correct and intact. The work took 5 days. The car was a daily driver for some salesman making his rounds. Oil change record shows that the car was maintained. Mileage is 50,000. It looked like the owner stuffed the car under something tall, like the rear of a semi. There appeared relatively minor front end damage when I got the car, but its forehead was wrinkled. I was very happy with it's condition happy 'cause none of the mechanicals or electrics were damaged. I finished dissecting the car in March of 2002, squirted oil in each of the cylinders and turned the engine over once. Since then it and its several boxes of components have been covered up and tucked away in the corner of a dry but un-heated garage. I have a bunch of supporting stuff (documentation, diagrams and tuning information) for anyone interested in installing and playing with this system. Cheers, John K Cincinnati, Ohio
JohnK Posted November 15, 2007 Author Posted November 15, 2007 Sorry for late reply - been away. $1500 would be reasonable given that it is a complete system. For example, I got a call from someone doing a GT40 kit - this would be perfect for such an app, since the harness would fit this rear and crosswise installation. Also, IF you want the stock engine management system, this is worthwhile since it's a turnkey in that regard and will be very well behaved. If you just need an engine, I've seen bare Zetec's for $400, but they were pretty rough. Cheers, John K
southwind25 Posted November 20, 2007 Posted November 20, 2007 John, we need to hold off on this, until we get what we will be recieving up and running properly first. But when we are ready, this sounds like the way to go.
JohnK Posted November 23, 2007 Author Posted November 23, 2007 I expect to be here for a while while I finish building my second choice Se7en. Look forward to hearing from you. Cheers,
