Have a beautiful set of steel S2 pre-crossflow intake manifolds.   Powdercoated in silver.  $250/pr
Also have one nearly complete and freshly sonic cleaned and rebuilt 40 DCOE 18, and one partially complete 40DCOE that needs more parts and assembly.   Both carbs have 32mm chokes, F16 emulsion tubes and 125mains and 155 airs.  The complete carb has new bearings, seals, throttle shaft, butterflies and is missing the following: (ONE screw top for one of the pump jets, TWO screw tops for the ball valves, Both push-in style auxiliary venturis.  This carb is shown in the 2nd, 3rd, and 4th pictures.  The disassembled carb (last picture) probably has 50% of the parts needed to complete as can be seen in one of the pictures but is ready for assembly.  $300 for both carbs and parts or $500 for everything listed above.   Craig Chima, CC Motorsports, Akron, OH (330) 807-0742 or chima97@aol.com
  • 1 month later...
