I have a used Stack ST8100 series race dash available. It was originally fitted to a 2002 Caterham 7 project I bought and in the end I decided not to use it as I wanted something with CAN connectivity with my ECU. I'm not very familiar with this unit, so please check out the Stack site here and the manual here. It comes with a wiring harness, three 10 BAR pressure sensors (one brand new, two used), two temp sensors (used), five switches (one is a spare), the U-shaped mounting brackets and the optional wheel speed sensor. I do not see a connector on the harness for the speed sensor, so I believe you would need to add wires for this (the manual has a wiring diagram).
It's in good shape, but obviously has some scratches on the front, being 21 years old. Also, some of the black "masking" on the front panel (not sure what to call it) has deteriorated a little. I believe Stack still service these, so it would be possible to have the front panel replaced and resealed if you really wanted a cosmetic refresh. I did fire it up on the bench to test the back-lighting, text display and that the needle calibrates to zero. I also connected the sensors and could see the temps change and the low oil pressure warning. I'm happy to send a video if you'd like to see it start up. But I am unable to give it a more thorough test than this as my engine is not running yet.
Asking $750. I'm in San Diego, if you want to see it in person.
Edited by Ferrino
added photos
  • 2 months later...
  • 2 years later...
13 hours ago, ErnestPage said:
Any chance this is still available, very keen if u still have it laying in yoru garage.
yes, where are you located?
Don't laugh, South Africa! HAHAHA, But I have a friend/company that ships things for me from the US. Are you open to chatting in private or on Whatsapp?
I can't send messages to you directly on here, as I'm newly registered
Of course: I just messaged you my contact details! Nobody mad enough to drive a 7 is in a position to laugh at anyone else 🤪
