sirlotus Posted November 4, 2023 Share Posted November 4, 2023 I am looking for any recommendations for LED headlights for my Superformance S1. Seems the the existing low beam on one unit is not working. Any help would be appreciated. Link to comment Share on other sites More sharing options...
MV8 Posted November 4, 2023 Share Posted November 4, 2023 I have tried many different led designs and housings and found many problems. I prefer to use H4 halogen bulbs in a Hella 6024 E-code lamp assembly for right hand drive countries. The ideal system imho is a projector with an led where low beam is partially blocked by a door. Selecting high beam actuates the servo, swinging the door out of the way of the full beam. The door is the shape of the cutoff. I've not seen anyone make this system to go in a 6024 7 inch housing. Do you want to match what you have or get a new pair of lights? Get DOT or E-code stamped lights; glass lenses if available. Link to comment Share on other sites More sharing options...
sirlotus Posted November 4, 2023 Author Share Posted November 4, 2023 Thanks for responding. This what I have and was just hoping for a similar retrofit. Michael Link to comment Share on other sites More sharing options...
MV8 Posted November 4, 2023 Share Posted November 4, 2023 I don't see an exact replacement currently available but these look similar and come as a pair for $52, shipped. A potential issue with any is the depth clearance in the bucket. https://www.ebay.com/itm/354873373115?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20231102134756%26meid%3D314306d81b7f4a0c9b3ba41a7c6c232b%26pid%3D101506%26rk%3D24%26rkt%3D25%26sd%3D381006279335%26itm%3D354873373115%26pmt%3D1%26noa%3D1%26pg%3D3458402%26algv%3DDefaultOrganicV9BertRefreshRankerWithKnnNlpV3RecallFitmentPromotionM2&_trksid=p3458402.c101506.m1851 Link to comment Share on other sites More sharing options...
sirlotus Posted November 4, 2023 Author Share Posted November 4, 2023 Oh, so you are saying that they are separate from the bucket? I had thought that it was an integral unit, light and bucket purchased together. If I can take the light unit out of the bucket, it would make things easier Forgive me, I am new to this. Link to comment Share on other sites More sharing options...
MV8 Posted November 5, 2023 Share Posted November 5, 2023 I see from your pic an led lamp assembly and a typical headlight bucket ring. I can't tell from your pic angle if there is a bucket behind it or not. If the back side is smooth and domed, then you have a bucket. Usually, the bucket is what attaches to the car below the headlight with a single vertical stud or bolt. Take and post a pic of the back of the light that also shows the attachment to the car. Link to comment Share on other sites More sharing options...
sirlotus Posted November 5, 2023 Author Share Posted November 5, 2023 Link to comment Share on other sites More sharing options...
MV8 Posted November 5, 2023 Share Posted November 5, 2023 Yes, you have a bucket with a hi beam indicator light on top (universal originally made for a motorcycle). It is likely the lights I listed are the same depth as what you have now if not a little thinner. Link to comment Share on other sites More sharing options...
sirlotus Posted November 5, 2023 Author Share Posted November 5, 2023 Thank you so much Link to comment Share on other sites More sharing options...
