Doug7L Posted November 30, 2023 Posted November 30, 2023 (edited) Used on my 2001 Caterham S3 for track days only. Never bent. Some minor scratched but otherwise in good condition. I believe the fronts are 6" and the rears 8" but will confirm as soon as I get the tires removed. I do not remember the exact offset but can measure it. I did need a 1/8" spacer on the rears to miss the watts links. Selection of spacers included. Each wheel with the slicks weighs about 20 lbs. $1500.00 plus shipping. Pickup preferred. Located in Newbury Park, CA. Doug doug@tidsales.com 805-402-1225. Edited November 30, 2023 by Doug7L 1
Jesse D Posted December 3, 2023 Posted December 3, 2023 Can you confirm the wheel widths and the offsets- I might be interested in just the wheels.
Doug7L Posted December 3, 2023 Author Posted December 3, 2023 Will do in the next day or so. I need to get the tires removed. Doug 805-402-1225 doug@tidsales.com
Doug7L Posted December 4, 2023 Author Posted December 4, 2023 DIMENSIONS ± FRONT REAR OVERALL WIDTH 7 ¾” 8 ¾” Bead /Tire width 7” 8” Back spacing 4 5/8” 5 ¼” If I did my calculations correctly that gives them about 19mm offset in front and 22 mm in rear positive offset. Please feel free to correct my calculations
Jesse D Posted December 4, 2023 Posted December 4, 2023 Thanks, that doesn't quite work for me, drat.
Doug7L Posted December 5, 2023 Author Posted December 5, 2023 What doesn't fit? I used 1/8" spacers on the rears so the tires would not rub on the Watts links.
Doug7L Posted December 5, 2023 Author Posted December 5, 2023 Kodiak can make the size and offsets you need. https://www.kodiakracingwheels.com/ You might also look at Jongloed. https://www.jongbloedracingwheels.com/wheels
Jesse D Posted December 5, 2023 Posted December 5, 2023 Thanks, I'm looking for a square setup at least 8-9" width. My current tires (Avon slicks) rub in the rear and I didn't like spacers with my studs. Thanks for the links.
Doug7L Posted December 5, 2023 Author Posted December 5, 2023 Longer studs are easy to do. Too wide a slick is harder to get warmed up because the cars are so light. I needed at least a full lap and that is if the weather and track are not cold.
Doug7L Posted December 9, 2023 Author Posted December 9, 2023 (edited) Question on Size. DIMENSIONS ± FRONT REAR OVERALL WIDTH 7 ¾” 8 ¾” Bead /Tire width 7” 8” Back spacing 4 5/8” 5 ¼” If I did my calculations correctly that gives them about 19mm offset in front and 22 mm in rear. Positive offset. Please do your own calculations to verify they will fit your car. $1500.00 Price lowered to $1200.00 Doug 805-402-1225 see also: https://www.californiacaterhamclub.com/forum/caterham/for-sale-wanted/38543-13-kodiak-3-piece-wheels A selection of spacers are included. Edited April 29, 2024 by Doug7L
Drakman Posted April 29, 2024 Posted April 29, 2024 Hi Doug, Do you know what just the wheels weigh without the tires? Did you run cycle wing front guards or clamshells? If cycle wing type did you have any trouble with tyre clearance with the wing stays? Dave
Doug7L Posted April 30, 2024 Author Posted April 30, 2024 (edited) The wheels are about 10lbs each without tires. Cycle wings on the front. No issues with clearance. My car was a 2001 build S3. De Dion rear suspension with Sierra Diff. Edited April 30, 2024 by Doug7L
