Could anyone know someone who has 1 or any information on a bike powered caterham,, like to know about trans an rear end n them ,, has there books or literature about them ,, any help would b greatly appreciated, thanks
The transmission is usually built into the bike engine case. Most any rear end can be used if it turns the right direction for the bike drivetrain or is flipped and the vent moved. Reverse options, charging capacity, gearing, etc. There is a lot to know about engineering and regulatory requirements if intended for road use in your area. Depending on what you want to do, a bike drivetrain may not be the best choice.
https://www.locostusa.com/forums/viewforum.php?f=10&sid=e097e6e39b96814ff313de5e1f6fbf0a
