Pectel T2 Programming Cable Needed
Does anyone in the LA area have a pectel t2 programming cable I could use? Happy to drive to you. I have a 1999 caterham with a 2.0L zetec engine with a pestle t2 ECU and need to calibrate the car for a new TPS sensor. Any help would be appreciated, thanks!
After a few attempts I was able to fabricate my own cable. Figured I should share the wiring schematic here because it was difficult to find online. I used a bestbuy insignia usb 2.0 to RS-232 serial adapter (with prolific chipset) because my laptop did not have a dedicated serial port and got some 1/4 stereo headphone plugs from guitar center.
serial port
pin 2 - receive data (RXD)
pin 3 - transmit data (TXD)
pin 5 - ground (GND)
1/4 headphone plug
tip (far end) - receive data (RXD)
collar (middle) - transmit data (TXD)
base (close end) - ground (GND)
