IamScotticus Posted May 28, 2024 Posted May 28, 2024 (edited) If you have one, you know what it is. Edited July 17, 2024 by IamScotticus
D_Mac Posted May 28, 2024 Posted May 28, 2024 https://watsons-streetworks.com/product/tsc-l75-series-switches/?attribute_switch-type=Chrome+Switch%2C+Green+Light&attribute_switch-size=22mm 1
IamScotticus Posted May 28, 2024 Author Posted May 28, 2024 (edited) That's an interesting item. The trafficator is still more advanced. Not only is the speed of the switch set with an adjustment on the housing, but the duration is selected by the degree of angle the lever is turned. And only one switch is needed. The existing wiring to the Lucas toggle switch can go directly to the timer switch. Edited May 29, 2024 by IamScotticus
jbcollier Posted May 28, 2024 Posted May 28, 2024 For those wondering... https://jollyrogersmotors.com/lucas-tps1-indicator/directional/flasher/turn-signal-switch-uk-made-new-clone.html 1
jbcollier Posted May 28, 2024 Posted May 28, 2024 Kind of neat, when they work. Most have dried out and cracked leather seals.
IamScotticus Posted May 29, 2024 Author Posted May 29, 2024 14 hours ago, jbcollier said: For those wondering... https://jollyrogersmotors.com/lucas-tps1-indicator/directional/flasher/turn-signal-switch-uk-made-new-clone.html Thanks. Good info. The Lucas looks more compact than the Semaphore
SevenAmerica Posted July 29, 2024 Posted July 29, 2024 (edited) Holden.co.uk supply them new. https://www.holden.co.uk/p/lucas-31250-self-cancelling-vacuum-indicator-switch-1 Edited July 29, 2024 by SevenAmerica
IamScotticus Posted July 30, 2024 Author Posted July 30, 2024 Thanks John. Check this out https://www.classicbulbs.co.uk/products/414-mechanical-flasher-unit
