Silverstone Motorcars Posted November 16, 2025 Posted November 16, 2025 I have just bought a Birkin - my second - and I'm not keen on the side mirrors. Attached is a picture of the one I had before and I would like to get these. Does anyone know whatthem? these are and where to get them? Thanks for any help
MV8 Posted November 17, 2025 Posted November 17, 2025 (edited) What is the mount thread size? Remove one of the side mirrors that you have now (cracking loose the jamb nut base at the windscreen), take the mirror to a hardware store, machine shop, or mechanic to determine if it is metric or sae and the thread pitch. The thread can be sae or metric M8 or M10, both sides right hand thread or one left hand thread. I'm guessing M10-1.5 RH and LH. Edited November 17, 2025 by MV8
Silverstone Motorcars Posted November 17, 2025 Author Posted November 17, 2025 I will check that out, thanks
BirkinBernie Posted November 20, 2025 Posted November 20, 2025 I found those mirrors at a motorcycle shop when I built my Birkin 25 years ago. They are the same as the mirrors Birkin was supplying at the time, but a lot cheaper. 1
Silverstone Motorcars Posted November 20, 2025 Author Posted November 20, 2025 On 11/17/2025 at 4:55 AM, MV8 said: What is the mount thread size? Remove one of the side mirrors that you have now (cracking loose the jamb nut base at the windscreen), take the mirror to a hardware store, machine shop, or mechanic to determine if it is metric or sae and the thread pitch. The thread can be sae or metric M8 or M10, both sides right hand thread or one left hand thread. I'm guessing M10-1.5 RH and LH. It's an M10 1.25 both RHT
Silverstone Motorcars Posted November 20, 2025 Author Posted November 20, 2025 56 minutes ago, BirkinBernie said: I found those mirrors at a motorcycle shop when I built my Birkin 25 years ago. They are the same as the mirrors Birkin was supplying at the time, but a lot cheaper. Thank you
MV8 Posted November 20, 2025 Posted November 20, 2025 M10-1.25, Emgo part number 20-46210 https://www.ebay.com/itm/205715575233
