USA 7s crew - I'm listing this here first, and would love to see the car go to someone in this community.  If it doesn't go fairly quickly, I'll be publishing it elsewhere - but wanted y'all to have the first crack at her.
MK Sportscars RX5 Turbo
$42,000
Located outside of Baton Rouge, LA.
Built by MK Sportscars USA, car has current registration and title, as well as an NHTSA issued 17 digit VIN. (VIN number 002)
Should be very easy to register in most states.
Based on the NB Miata drivetrain, she’s been pepped up with a small turbo, that makes her a blast to drive.  Very quiet, very torquey, but sneakily fast.  Boost is incredibly smooth, starts to build at about 2200 RPM.  No sudden surge to upset the car, almost no turbo lag.
ECU is managed by a Motorsports electronics ECU.  The car was tuned by Alex at Digitune – very, very reputable tuner for the ME ECUs, and a miata specialist.  (Great guy to work with by the way)
I’d estimate 210  wheel HP.  Turbo is limited to 11PSI, could be increased, as there is electronic boost controller installed.  She’s quite quick already.  11 PSI is a good safe limit for reliability IMO.
The Innovate PSB-1 gauge above the wheel displays both intake pressure and air fuel ratio via a Bosch wideband O2 sensor.
Roll hoop can be removed and upgraded to an FIA cage should it be desired in the future, chassis is provisioned for the cage already – ie – they are swappable.
Today’s cost is $29,800 for this kit imported to the US.
Plus you’d still need a low mileage donor miata, as well as adding the costs and time to refurbish the parts.
And then build it….
Car has about 150 miles on her since she was finished.
She’s been shaken down thoroughly, and is ready for pickup today.
If the buyer wants to add weather gear, wind deflectors, fender guards, or any accessories, I’d can supply and install if desired.
Parts were sourced from an NB Miata, 80K on the odometer.  Unmodified donor vehicle, was in great shape and drove perfectly.
Cold start video here:
Cold Start
8 Minute test drive video:
Test Drive
(Forgive my lack of video editing skills)
More pics:
RX5 250 Pics
Parts replaced with new during the build:
Front and Rear Wheel Bearings
Axles
Pads and Sport Miata Rotors
Differential seals, all
Differential braces welded to housing
Transmission seals, all
Upgraded Flying Miata Shifter Rebuild Kit
Water Pump
Thermostat
All engine seals
Valve Cover Gasket
Timing Belt and tensioner
Fuel Filter
Lower Ball Joints
949 Racing Clutch
949 Racing 8.8 lb Lightweight  Flywheel, perfect match in this lightweight car – like OEM miata engagement
New Spark Plugs
Detailed Specs:
15 x 7 / 15 x 8 Wheels with Falken Azenis 660 tires, 205/50 F, 225/45 R
Innovate WB/Pressure Gauge
ME221 ECU
Limited Slip Differential
Larger Sport Brakes / Rotors
Wilwood Front Brakes with stainless braided Goodridge lines on all 4 corners
Mintex Brake Pads (Soft)
2” 4 Point Harnesses FIA certified
Coil Over Single Adjustable Shocks
Odyssey AGM Battery
Walbro fuel pump
Bosch EV14 640cc Injectors
Radian Fuel Rail, converted to return style system
12” Cooling Fan / Oversized 55MM Radiator
Front Mount Intercooler
Electronic Boost Controller
Removeable Headlamps
Suede steering wheel included, some pics show leather – I didn’t care for the leather one.
SAE bulkhead fitting under the dashboard for a battery tender.
Multiport USB charger with voltage display.
james@mksportscarsusa.com
Edited by MK Sportscars USA
  • Like 5
Nice looking car.  I am curious about the NHTSA VIN.  Does the car show up as a 2025 MK Sportscars RX5 250 or as a 1960 Lotus or something like that?  California things...
