craig chima Posted 56 minutes ago Posted 56 minutes ago Have a couple of items that may be of interest to folks with A-series powered Lotus 7's. These are both for Sprite gearboxes and one is an extended shifter housing that moves the shifter location rearward by about another 4" and gets the shifter out from under the dash into a much more user-friendly location. It is a direct bolt on piece. $300 and it even comes with an original wood Lotus shift knob! The other is a "quick shift kit" for Sprite gearbox. It changes the fulcrum/pivot point and shortens the long, stock shift throw to about half. Again a direct bolt on piece. $100. Pix attached 1
