JB455 Posted 20 hours ago Author Posted 20 hours ago Almost looks like maybe you need to open up the holes a little bit so the grommet doesn't deform? I had to open mine just a little to even be able to get the lights to seat.
Silber Posted 19 hours ago Posted 19 hours ago 26 minutes ago, JB455 said: Almost looks like maybe you need to open up the holes a little bit so the grommet doesn't deform? I had to open mine just a little to even be able to get the lights to seat. I think you're right, as it was a really tight fit. I may go that route and get these grommets to fit better, but I'm also thinking about finding an alternative that covers a little more around the hole, as the outer mounting holes from the original lights are not covered well. Either way, I'm pleased with the lights and are substantially better than the factory units. Thanks for pointing them out to me!
