tnttim Posted August 28, 2008 Posted August 28, 2008 I found a great set of bushing o use for the assembly of the A-Arms. Rubicon Express Pn# RE3762 with a machined sleeve. There is also an economy model RE3764 with a pressed steel sleeve. http://www.usa7s.com/aspnetforum/upload/2025530577_0828081910.jpg http://www.usa7s.com/aspnetforum/upload/342725024_0828081911.jpg http://www.usa7s.com/aspnetforum/upload/1807075946_0828081911a.jpg You will get a sleeve and an hour glass shaped bushing. The inner sleeves are 10mm ID and can be punched out to 1/2". The steel sleeve has a ridge in the middle to keep the bushing from slipping. Steel Sleeve dia. is 1.75 and when assembled is 2" wide. They are a little pricey but worth it. $19.00 ea. for the nice ones. I got mine at Jeeperz Creeperz in Wyandotte, Mi. (734) 281-8141.
tnttim Posted August 28, 2008 Author Posted August 28, 2008 Here are a few of the new bushing installed on a set of old ARCA A-Arms I found and am going to use. http://www.usa7s.com/aspnetforum/upload/212409172_0828082144.jpg http://www.usa7s.com/aspnetforum/upload/188120887_0828081909.jpg I had to use a vise and smooth plate to squeeze the rubber in. A little spit on the rubber and it slides right in. Then just press in the metal bushings. ( Hey look I can weld). http://www.usa7s.com/aspnetforum/upload/1456486407_0828082155.jpg NEW HOTNESS VS OLD AND BUSTED. http://www.usa7s.com/aspnetforum/upload/1129245236_0828082202.jpg That and the old one had some weird size bolt/bushing combo I didnt want to deal with. 1/2" for the new and a lot easier to find hardware. Smaller size and I now know where to get replacments. tnttim
Al N. Posted August 29, 2008 Posted August 29, 2008 You know you're on an enthusiast site when you see a thread topic like "Wonderful A-Arm Bushings found" — and you click on it yourself even though you don't even have a car or are in the middle of build!
Donnie Posted August 29, 2008 Posted August 29, 2008 Thanks for sharing and documenting for future reference.
Arya Ebrahimi Posted August 29, 2008 Posted August 29, 2008 Haha, why didn't you guys just ask? That's a very common bushing in the offroad world. Commonly referred to by Rubicon Express as their superride bushings.
