slngsht Posted November 19, 2006 Posted November 19, 2006 All, since transition to vBulletin is taking longer than expected, I made a couple of minor changes... 1- top nav should put itself in the right place, and its background should always be blue (simple things we normally take for granted http://www.usa7s.com/aspnetforum/images/emoticons/smile5.gif ). 2- When you go to view posts now, the topics should take 100% of the available width If these changes are causing problems for you, please let me know.
slngsht Posted November 19, 2006 Author Posted November 19, 2006 also fixed the way quotes are shown in posts.
slngsht Posted November 19, 2006 Author Posted November 19, 2006 also eliminated the extra "reply" button from the bottom of the page that took you to another page for replying. That functionality is available from the "reply" link on every post. This one was requested by LocostV8 a while back...
locostv8 Posted November 19, 2006 Posted November 19, 2006 Thanks. I lost count of the number of times I retyped a message because I hit the wrong button.
slngsht Posted November 19, 2006 Author Posted November 19, 2006 Thanks. I lost count of the number of times I retyped a message because I hit the wrong button. I had done the same http://www.usa7s.com/aspnetforum/images/emoticons/cheers2.gif
slngsht Posted November 21, 2006 Author Posted November 21, 2006 another little feature... if you want to link to a You Tube video, you can now embed it directly here... Simply get a video id, like this: sGnc8meASEQ and put it in between YT tags (remove the spaces): [ YT ]sGnc8meASEQ[ /YT ] Here is the end result: slngsht2006-11-21 18:55:14
