TheDingo8MyBaby Posted March 12, 2009 Share Posted March 12, 2009 I'm having trouble finding a couple parts for my webers. The set screw and jam nut fell out of the bottom of the carb while doing a spirited run last weekend. Now the choke tube wants to rotate in the carb which blocks the main jet. The effect is that I end up running on 3 cylinders when trying to apply more than 20% throttle (using the main jets). If you'll notice the drawing, I'm looking for items 24 (34710.003) and 28 (64820.006) on this drawing. (the lock nut and set screw that hold the venturi in place) http://www.webcon.co.uk/weber/40dcoe.htm The lock nut is no issue, but every US weber distributor I try does not seem to carry the set screw. I've even been told weber discontinued the part. Does anyone have any good sources for weber parts? Link to comment Share on other sites More sharing options...
DB6 Posted March 12, 2009 Share Posted March 12, 2009 Go to the bottom of this page link ( I thought you may like to read it, and click on the link for "Pierce". Good Luck David http://www.tjwakeman.net/TR/WeberDCOEinfo.htm#idle Oh there is also Dave Bean in CA, Tom is the 7 expert. http://www.davebean.com/ Link to comment Share on other sites More sharing options...
TheDingo8MyBaby Posted March 12, 2009 Author Share Posted March 12, 2009 Thanks DB6. I gave pierce a call and they were able to resolve things for me. Apparently weber has their part numbers wrong. it's 64830.006, not 64820.006. Link to comment Share on other sites More sharing options...
