Im in the process of looking around for new shocks to replace my spax shocks that come with the Birkin, I have a chance to get some good front GAZ shocks from a supplier here in NZ, so what I would like to know is what should I be asking for I know that there is a recommended length of 294mm between the shocks mounting eyes when they are in place and the car is sitting on the ground, there will also be a compression size and fully extended size too. I know a few guys here have put new shocks & springs on there Birkins so any info would be most helpfull. I also will be getting new springs too, I would like to know whats recommended just for road use on the front & rear.
Cheers KiwiBirkin
Here are the Front damper dimensions for a 2001 Birkin front.
Full extension...32.9cm between eye centers.
Full compression with 26mm thick bumpstop..26cm.
Body length...18.4 cm
Body diameter...43.5mm
Spring free length is 8"
rate is 300 Lb/in
inner diameter is 49mm
Outer diameter is 68mm
I have seen the Koni 2812 mentioned as a suitable replacement.
I have used Carrera 6244/874L as replacements whilst retaining the stock springs. These are only height adjustable unfortunately...Too soft for track use, imo.
m
