7ishNZ Posted May 11, 2009 Posted May 11, 2009 I am keen to know what diffs people are using in their bec's... something with an ali housing and a ratio around 3.3 would be ideal.. Thanks.
BobDrye Posted May 11, 2009 Posted May 11, 2009 What's the ratio, what does it weight, and most important, how many foot pounds of torque are you going to punish it with? Ask 7evin!
7ishNZ Posted May 11, 2009 Author Posted May 11, 2009 Yamaha R1, about 500kgs all up.... 195x55x15 tyres....
Spaz Posted May 11, 2009 Posted May 11, 2009 (edited) I got a ford sierra rear end hook-up to a Honda firebalde that puts out 88.30 Nm (9.0 kgf-m or 65.1 ft.lbs) @ 8500 RPM on some 185x60x14 tyres. (I need to check the tires size again) Edited May 12, 2009 by Spaz
Hank Posted May 11, 2009 Posted May 11, 2009 IRS, Ford Sierra, 3.62 rear ratio with a Quaife LSD. No clue what it's rated for power/tq wise. http://hanksmegabusa.com/images/113008/09.jpg
BobDrye Posted May 11, 2009 Posted May 11, 2009 A non turbo Busa engine develops about 100 ft lbs of torque. Why not try to find something very light?
Hank Posted May 12, 2009 Posted May 12, 2009 Bob, if you are speaking to me I will be putting a turbo system on soon.
Spaz Posted May 12, 2009 Posted May 12, 2009 Hank, I don't see pins in your seatbelt hooks!!! Better add that to the "list" before any track day
Hank Posted May 12, 2009 Posted May 12, 2009 Spaz, I will be installing 6-pt harnesses to replace the 4-pt Westfield harnesses in a few weeks. What pins do you speak of?
rotus8guy Posted May 12, 2009 Posted May 12, 2009 Re: Pins The little holes in the latch part of your seatbelt hooks. They take cotter pins to keep the belts from coming off accidentally.
BobDrye Posted May 12, 2009 Posted May 12, 2009 Bob, if you are speaking to me I will be putting a turbo system on soon. What weapon do you want me to bring?
Spaz Posted May 12, 2009 Posted May 12, 2009 (edited) Re: Pins The little holes in the latch part of your seatbelt hooks. They take cotter pins to keep the belts from coming off accidentally. Yep, what he said. I can just picture it now, Hank is at the track for his first test run and the teck guy walks up to the car and says, where are the cotter pins, I can't let you run unless you have cotter pins on your belts. Edited May 12, 2009 by Spaz
BobDrye Posted May 13, 2009 Posted May 13, 2009 Bob, if you are speaking to me I will be putting a turbo system on soon. Hank: Are you using a kit?
Hank Posted May 13, 2009 Posted May 13, 2009 Bob, I haven't bought anything yet. Any recommendations? I'd like the turbocharger to tuck under the engine and only the downpipe (exhaust) stick outside the body. Here's a pic: http://www.hanksmegabusa.com/images/P3240414.JPG
Spaz Posted May 13, 2009 Posted May 13, 2009 Holy Mother... That is crazy Hank. You have any more pictures of that car?
Hank Posted May 13, 2009 Posted May 13, 2009 Spaz, unfortunately that is the only picture I have of that car. I found it on the WSCC Forum.
BobDrye Posted May 13, 2009 Posted May 13, 2009 I'm going to say that the picture is of a Mitsubishi TD04L-14T-6 Volvo Turbo.
