Brake assembly - need some measurements
First here's a shot of what the bracket looks like. This is one of the early brackets, which is different than what most of you probably have:
http://www.usa7s.com/forum/uploads/slngsht/pict0236.jpg
The dimension measured below is from the top bolt of the clutch flange, to the sheet metal. it is the same dimension from the top bolt of either master cylinder as well. With my new cylinders, this is too high - The hood doesn't shut properly.
http://www.usa7s.com/forum/uploads/slngsht/pict0234.jpg
Also, as you see below, the push rods are completely out of alignment, and that's probably b/c the pedal was cut and shortened at some point.
http://www.usa7s.com/forum/uploads/slngsht/pict0235.jpg
http://www.usa7s.com/forum/uploads/slngsht/pict0237.jpg
Anyway, I can make a new bracket, but I'm wondering if the later style brackets locate the master cylinder at a lower position. If so, I will try to get one through Dennis.
  • 3 weeks later...
The later style brackets do mount lower.  I measured 4 3/8" to the
bolt that you measured at 5".  The later brackets (mine at least)
are an off the shelf Tilton item mounted atop 1"x2" steel tubing.
Hello to all on the forum, I've been lurking for a while but the mood
finally struck me to post.  I met Rob a few months back when he
came down to look at my Rotus with an eye towards a purchase. Mine
right now needs more work than he wanted to get into.  I'm glad
you found a Seven Rob!  This forum has helped spur me to get into
the garage and get the Rotus back on the road.
Cheers,
John Bowman
Peachtree City, GA
Thanks for the measurement. I'm taking mine apart tonight to get the pedal shortened, and move the master cylinders lower. Should be relatively easy.
Please post some pics of your car in the General section.
New and improved! no problem with locking up on demand now.
http://www.usa7s.com/forum/uploads/slngsht/2005-11-20_225858_CIMG0015.JPG
What did you change about the brakes?
Rob Mitchell, Atlanta, GA
The bracket that holds the master cylinder is much shorter now, and the master cylinders are moved down by about 1.5".
The brake pedal now has much more leverage (used to be around 4:1 - now it's at 7:1).
Part of this problem was self inflicted. I went with 3/4" bore master cylinders instead of 5/8", which made the pedal effort much higher.
  • 1 month later...
Hello to all on the forum, I've been lurking for a while but the mood finally struck me to post.  I met Rob a few months back when he came down to look at my Rotus with an eye towards a purchase. Mine right now needs more work than he wanted to get into.  I'm glad you found a Seven Rob!  This forum has helped spur me to get into the garage and get the Rotus back on the road.
Hi John!
I just found your post!! It was a pleasure to meet you and talk about your car. Get it together and maybe we could meet in the spring!
