andrew7 Posted December 11, 2009 Share Posted December 11, 2009 Here are some build pictures. A standard frame should have enough room. The tape is across the velocity stacks. the pan is around an inch below the frame. I did not want an air filter sticking out so a custom air box was fabricated. I concede a ITD filter like Jeff Underwood's car will make more horsepower but I'm not losing much and prefer the aesthetics. I believe the nose is 1" taller than standard, you can see I had to split it and add 4". Link to comment Share on other sites More sharing options...
locost7018 Posted December 12, 2009 Share Posted December 12, 2009 Oooo, I like that tunnel!! Russ Link to comment Share on other sites More sharing options...
Spaz Posted December 14, 2009 Share Posted December 14, 2009 Thank you for posting. Here are a few shot of my 1993-1999 motor. http://www.redpepperracing.com/gallery/d/233055-2/Air+Clearners.JPG Link to comment Share on other sites More sharing options...
