thegoat Posted June 18, 2010 Posted June 18, 2010 Anyone know where the VIN on a newer Birkin frame is located? I know my car has one, but I don't recall ever running across it during the construction. Thanks all.
Birkin42 Posted June 18, 2010 Posted June 18, 2010 For Zetec powered cars, it on the upper left engine bay diagonal tube stamped into a welded on plaque. In looking through your build photos, it looks like Brikin has moved it to the upper right diagonal engine bay tube. It looks like it should be just under your exhaust header where it comes off the head. It also use to be stamped into the rear shock mounts just where the roll bar attaches. Again, not sure if Brikin has moved this or done away with it. I could be wrong.
thegoat Posted June 20, 2010 Author Posted June 20, 2010 That is where it is. Right underneath the headers. Thanks!
