For folks that don't get the gauges with thier bike engines...those can be found on ebay from time to time as well. I picked up an R1 cluster for less than half of what a new one would cost. If you get enough of the wiring, it is just plug and play.
HTH
I agree with R1 on this. The newer bikes are very different. After I got my engine I decided to get the upper harness, instrument cluster and ignition switch with key for $300 shipped. The big bonus is all functions needed; turn, high beam, low fuel, water, speedo,tach with shift light PLUS the diagnostics. My engine wouldn't start and the computer had shut down the FI. Why? After pulling codes off the cluster, the tip over switch was mounted 90 degrees off. and it also though the kick stand was down. http://www.usa7s.com/aspnetforum/images/emoticons/lol.gif I couldn't have found it with out reading the codes.
Last fall I decided to pull the useless swithes off the car. The tip over switch was unplugged and the engine wouldn't start and it flashed a code. I disassembled the switch, it had 4 wires going to a small computer board and chip, its not a simple mercury switch. I plugged everything back and she's happy 'n running. For us BECs, the electronics are wired into everything. The car guys they can buy any gauges with senders and wire them in independently.
I know i'll be busy by 7/7/7, but a kick stand would've made a great gag gift for the BEC guys http://www.usa7s.com/aspnetforum/images/emoticons/lol.gif
It's an important part to have...if it is down the car won't keep running when I put it in gear. http://www.usa7s.com/aspnetforum/images/emoticons/biggrinjester.gif
