twobone Posted September 2, 2010 Posted September 2, 2010 I'd like to refresh my bushings in my front suspension. In particular the top shock bushing is shot and the bottom trunnion bushing is also shot. I can find the trunnion set: https://www.caterhamparts.co.uk/product_info.php?cPath=144_148&products_id=4544&osCsid=463f8499f849ef77ac4b20496dfc12de But which of these do you think is the top shock bushing where it mates to the top wishbone? #1: https://www.caterhamparts.co.uk/product_info.php?cPath=144_148&products_id=1472&osCsid=463f8499f849ef77ac4b20496dfc12de #2: https://www.caterhamparts.co.uk/product_info.php?cPath=144_148&products_id=2119&osCsid=463f8499f849ef77ac4b20496dfc12de
bsimon Posted September 2, 2010 Posted September 2, 2010 #1 looks about right for the shock bushing if you have Spax dampers. The Bilstein dampers are different. Not sure what was used on Koni dampers. #2 is the upper suspension link bushing. It's pressed into the cast upper link on the inboard end of Lotus Sevens and live axle Caterhams. It's actually a 636 suspension bushing that has been shortened and peened over. If your outer ball joint is worn, it's cheaper and a lot less painful to get a complete replacement cast upper link with the BP636 bushing already installed. Give Ben a call at CaterhamUSA and he can sort out what you need.
