I'm interested, can you post some pictures of how they attach to the windscreen frame?
Hi Skip.
They bolt thru the stanchion hole. You do have to drill/boreout a wider hole in the stanchion and the body to 3/8th of an inch I beleive. The end of the mirror has a threaded end that bolts idirectly on the inside the chassis. The mirror comes with the correct nut.
twobone,
Thanks for the info. It won't work for me as I put the bracket with captive nuts on the car to avoid having to fiddle with nuts when changing from windscreen to the Brooklands screens.
  • 1 month later...
