Does anyone know the correct size/spec for the 4 o-rings used on the single throttle body plenum that seal around the intake ports?
Haven't been able to visually size match at the local hardware store, looks like I will need to order some..
Adam
Hi Adam,
I just googled "Duratec Intake o-ring size" and it appears to be a 2" o-ring.
I would measure the old o-ring ID and OD and cross section width and then use the Parker O-Ring catolog to find the closest o-ring that fits. You might want to look at the temp range and slect the correct o-ring based on the size and tempature range most likely a Viton 2-136 found on page 228 of the catolog link that is below.
http://www.parker.com/literature/ORD%205700%20Parker_O-Ring_Handbook.pdf
Hope this helps.
Martin, thanks. I think it is the 2-033 (2" ID, 1/8" width). Got a link to where I could buy them online by any chance?
Thanks.
Adam
