How did you get a "7" in your front grill? And does your ET / CHMSL light work well?
More pics please .. Dash .. instrumentation .. what each switch and knob does .. How about pics of the heater setup?
Rob Mitchell, Atlanta, GA
solder_guy38725.5800231481
Rob, for the the grille I made a full size template starting with a picture I came across of a Caterham. Had a local shop bend up some wire and tack it together. If you would like I can trace my grille on to a peice of paper and send it to you. It is one of several ruses I use to counfound the judges at the various shows . Note also the unique graphics on the stering wheel and road wheels. It drives them nuts!Yes, the CHMSL works fine. I think it is Dennis' standard issue. I did change the rear license plate light. I did away with the large "gabong" Dennis uses and have a liscense plate frame with an integral light. Much cleaner. I'll do a series of pctures on the instrument panel in a week or so. Right now I am recovering fom one helluva cold.         Red Baron
Thanks .. I would like to have that .. maybe add to my car ...
I'll have to go look at your pics again. I look forwad to seeing more of your car!
Rob, just out of curiosity, what is the status of your car? Do you have it in hand, is Dennis in the process of building  it or is it just on order?        Regards, Red Baron
Red Baron,
My six year old son saw the "7" in your grill... Apparently we're doing a father / son project to put one together for my car :)
Dennis has it in his shop .. It is chassis #14 listed here on www.usa7s.com The head has been pulled off to redo / reseat. I own it .. but I have not yet seen it in person!
