vetterestorer Posted August 30, 2011 Share Posted August 30, 2011 Need the plastic or fiberglass plenum that sits on the stock zetec throttle body on a 2000+/- Caterham or Birkin. Can be the type held on by two bolts or the type held on by a hose clamp. Mine split and I am down to I get another. Richard Link to comment Share on other sites More sharing options...
Mike Rohaley Posted August 30, 2011 Share Posted August 30, 2011 Richard, I have one boxed up since I switched to a different intake system with the idea that I could return it to stock form should I seek originality at some point. If Caterham USA doesn't have one and you will be otherwise out of commision I would be willing to part with it. I would prefer to keep it if another source is out there for you but if not, you can contact me at: mrohaley @ oh.rr.com (ignore the spaces). -Mike It is off a 2001 Zetec VCT Caterham. Link to comment Share on other sites More sharing options...
breezy7 Posted August 30, 2011 Share Posted August 30, 2011 Is this a fit? http://www.focusfanatics.com/forum/showthread.php?t=262731 Link to comment Share on other sites More sharing options...
vetterestorer Posted September 1, 2011 Author Share Posted September 1, 2011 Thanks Mike, I will keep looking and get back to you either way. The stock Focus parts do not appear to be correct, from what I have found out so far, the part is used on Caterham and Birkins and probably others.. Richard Link to comment Share on other sites More sharing options...
G2sound Posted September 7, 2011 Share Posted September 7, 2011 I just put a crated Zetec Z3 into my S1. I have the entire stock Ford intake including injectors sitting in a box as I am using ITB's. Is this what you were looking for, or is it specifically a Caterham part that you need? Link to comment Share on other sites More sharing options...
vetterestorer Posted September 9, 2011 Author Share Posted September 9, 2011 Unfortunately, it is a custom part for Caterham and Birkin from what I have seen. Stock intake and throttle body and then the part I need which is very low profile plentum/air box. Thx., Richard Link to comment Share on other sites More sharing options...
jlumba81 Posted September 9, 2011 Share Posted September 9, 2011 Can you post a pic of the damaged intake plenum? Can it be taken to a local fiberglass shop to be repaired? Link to comment Share on other sites More sharing options...
vetterestorer Posted September 13, 2011 Author Share Posted September 13, 2011 I'll check and see if it is repairable. Richard Link to comment Share on other sites More sharing options...
