ERNSTEVERYTHING Posted December 2, 2011 Posted December 2, 2011 (edited) Hi I'm looking to paint or wrap my superlight , in gloss black (currently yellow). Has anyone, that has had their car wrapped, had issue's with: * Rock chips, that show through to paint below * wrap melting near the exhaust * fuel coming in contact with wrap * hard to get to edges that can't be wrapped I'm quite particular and am steering towards paint at this point, as I can't stand the idea of being able to see yellow peeking through somewhere. Any feedback, would be appreciated. Thank you Anthony Edited December 2, 2011 by ERNSTEVERYTHING
jimrankin Posted December 2, 2011 Posted December 2, 2011 I have a complete "clear" wrap and it has the following problems. Where it gets hit by small stones etc. it turns from clear to a semi-tranlucent/white at the edges and looks a bit damaged/strange (no worse than a chip I guess) with no way to fix these. If it gets rubbed hard by anything (think cone at autocross) it gets a discolored haze and you can not rub it out, tried every product possible. It has as many good points as bad as a clear but may not work that well as a color change wrap and your small dings won't be easily patched. Not sure it's all that much cheaper than a paint job if you strip the car down and do all the non-removable parts masking yourself.
