I've moved on from the MR2 world and am getting started with 7s. I planned to use this engine that I had built for my "2" but am going to go with something more plug and play. I'm limited on time and not as skilled at custom work as many of you.
The tune is still very conservative, even being the highest hp N/A MR2 gen 3 motor out there. It would also make a tremendous turbo engine as well if someone chose to simply swap in lower compression pistons. All work has been professionally done by Chris Katthage at Enginelogics, so you know it is top quality. All invoices have been retained.
I travel frequently for work, so please e-mail me if you have interest in discussing further.
There is flexibility in the price; depending on what components you are looking for/your personal build intentions. This is a great opportunity for a top quality drivetrain at a value price. Titanium rods alone have more than doubled in price since the Boeing 787 went into production! I will also give you the map from my MoTeC m400 to help you get started with your own ECU.
$10,500 OBO
I'm also willing to entertain splitting the block and head if to bring the cost down but there will need to be buyers for both components lined up before a sale.
Interestingly enough, a Tom’s engine is advertised for sale at $16,990 with less power! http://www.tomsracing.co.jp/product...g.php?mprID=285
Many thanks for your interest,
Joe
joeschroeter at gmail dot com
Engine Specifications:
Custom CP 13.5:1 88mm Pistons w/ 3-D Internal Mill, Lateral Gasports, etc.
Swain Ceramic Coated: Combustion Chamber, Valve Faces, Intake and Exhaust Ports (TBC)
Swain Piston Dome & Skirt Swain Ceramics (TBC & PC9, respectively)
3rd Generation "GE" Head w/ Race Porting by Chris Katthage at Enginelogics
Custom Cam Sync
Custom 304 Advertised Duration, 13.5mm lift Camshafts (257 @ .050” IN/ 257 @ .050” EX billet cams)
Fidanza 6061 Aluminum Adjustable Cam Gears
Ferrea Custom O.S. Stainless Valves, 36mm IN 30mm EX – Modeled after Blacktop BEAMS
Custom 50mm Individual Throttle Bodies
Custom Vacuum Reservoir
Custom Fuel Rail System
Subaru WRX 565cc, Metal Pintle Tip, (8) Hole Cap High Impendence Injectors
Walbro 255LPH High Pressure Fuel Pump
Caldina OEM (ST215) COP Ignition
Alamo Autosports 6061 Distributor Cap Off
OEM Shim Under Bucket Modification
Custom Machine Work - Cut Exhaust Side Shim Buckets
Custom Machine Work - Hand Cut Lifter Cut Outs to Accommodate Larger Cam Shafts
Ferrera 85lb. Dual Valve Springs
Ferrera Titanium Valve Spring Retainers
Crower Custom Titanium Long-Rob Setup w/ rod ratio of ~1.7
Ishihara-Johnson Teflon-edged Crank Scraper
Lightened, Chamfered, Balanced and Micro Polished 5S Crankshaft
Custom Crank Trigger
93 OEM “5S” Treated Block
Custom Lightened and Balanced Flywheel
OEM Modified GenIII 4-2-1 Header, Swain White Lightning Coated
OEM GenIII Cylinder Head w/ Swain Tech Chamber and Port Ceramic Coating
Custom Exhaust, Swain Tech White Lightning Coated
Speed Source Urethane Motor Mounts
XRP Braided Stainless Hoses
RacerX 6061 Alternator Mount
OEM 70amp (lightweight) Alternator
Thrust Washer
3S-GTE
Main Bearing Set
Main Bearing Set
0.025 over size
Oil Pump Assembly
Oil Pump Cover Gasket
Rear Main Seal
Cam
Seal
Tensioner
Primary Idler Pulley
Secondary Idler Pulley
5SFE Water Pump
X-Line 3 Row Aluminum Radiator
Custom Coolant Neck
0.8mm 3SGTE Head Gasket
ARP Head Stud Kit (3S-GTE)
Timing Belt for 3S-GTE
Bore, hone, Align Bore and Deck 5S Block
Custom Oil Filter Relocation Kit w/ Stainless Lines, Increased Capacity
Custom Fuel Rail
Aeromotive Fuel Pressure Regulator
8 bar pressure sensor w/adapter, Fuel and oil pressure
3-pin PSI transducer term kit
Bosch engine temp sensor 1/8 NPT Bosch Sensor Term Kit
Air temp sensor (Bosch)
Air/Engine Temp / Lambda Sensor Term Kit (Bosch)
Engine (water) temp sensor (Bosch)
1-bar map sensor (BARO)
1-Bar Pressure Sensor Term (GM) Kit (BARO) (100 KPA)
108 KPA BARO pressure sensor
1-Bar Pressure Sensor Term (GM) Kit (BARO) (108 KPA)
LSU wide range lambda sensor 4.0 LSU Lambda term kit
Most of the ancillary parts that were refreshed in the rebuild along with complementary machine work are not listed, for space purposes. This is a lot of data to sort through, so please let me know if anything is obviously missing.
The blue line is the un-ported head with stock exhaust valves.
The red line is the custom exhaust valves in ported head.
The orange line is the stock head with un-ported intake valve.
The yellow line is the custom intake valves in ported head
The red and yellow lines are measured over more lift areas because of the cams being used.
Lift is measured in increments of 0.050”
Test was done at 28 inches of vacuum
Average airspeed is 345 ft/sec
