I wired in my new High Beam Headlight Switch this weekend.
I was not pleased with the way that Rotus had wired the headlights .. there was a cheap ON-OFF-ON switch that selected between low and high .. after pulling out the park / head light main switch.
So .. I rewired the main switch to activate the low beams when pulled out .. and ..
I wired my new ON-OFF-(ON) switch to activate the Hi beams via a relay that cuts off the low beams. (ON) means momentary on .. which means that I can flash my high beams briefly if necessary.
The relay is the standard 5 terminal automotive relay.
Rob Mitchell
Do you have a link to the switch you used?
GC Switch brand: silver bat switch.
Here's the part number: 35-0153-0000 which is the ON-OFF-(ON).
Rob
