ultraslow Posted August 31, 2013 Share Posted August 31, 2013 Has anyone had any experience replacing regular gear lube with synthetic?; Same weight of course. I did and now I can't get the shifter to cross over to the 3-4 side of the pattern. After pumping out and refilling, the car sat for about three months while I had the master cylinder repaired. ultraslow Link to comment Share on other sites More sharing options...
SkinnyG Posted September 1, 2013 Share Posted September 1, 2013 I've had GL5 gearlube in a GL4-spec transmission by mistake, it started eating the synchros, but not a shift gate issue. Perhaps it's something else? I can't see the oil doing that.... Link to comment Share on other sites More sharing options...
MHKflyer52 Posted September 2, 2013 Share Posted September 2, 2013 Has anyone had any experience replacing regular gear lube with synthetic?; Same weight of course. I did and now I can't get the shifter to cross over to the 3-4 side of the pattern. After pumping out and refilling, the car sat for about three months while I had the master cylinder repaired. ultraslow I've had GL5 gearlube in a GL4-spec transmission by mistake, it started eating the synchros, but not a shift gate issue. Perhaps it's something else? I can't see the oil doing that.... Have to agree with SkinnyG just changing the oil should not cause that to happen. Sounds like maybe something is lodged in the shifter console. :driving: Link to comment Share on other sites More sharing options...
ultraslow Posted September 6, 2013 Author Share Posted September 6, 2013 Problem solved, Thanks all. ultraslow. Link to comment Share on other sites More sharing options...
ultraslow Posted September 16, 2013 Author Share Posted September 16, 2013 See the above post, "Interesting problem solved" Thanks for the input. Sorry I am so slow in responding; been out driving! ultraslow Link to comment Share on other sites More sharing options...
