http://www.flickr.com/photos/88668757@N08/with/10280027955/
Photos
Locost and USA7's guys get dibs, before I craigslist. Offer for the whole lot?
Stuff for sale.
3” V-band clamps stainless 4ea. $10 ea.
3” Stainless Downturns, 2 ea. $8 ea
3” Pypes stainless glasspack mufflers, polished. 2ea. $20 ea.
Universal spun catalytic converters. Used 2k miles, $10 pair.
Car Chemistry 4 disk muffler insert 3”, press out or weld-in. 3” mild steel. $10 pair
Car chemistry stainless steel wool/muffler pack. $10 for 2 bags
Stock car, late model, adjustable panard bar mount. 2ea. $10 ea.
Stock Car, ballast mount. 1.5” roll bar. 4ea. $5 ea
Stock Car 1.5” Longacre panel mount, 2 ea. $15 for the pair
Craftsman work bench, bent right leg. No room. First $20. No vice or breaker. Bench and Bench top only.
Trailer Bed Tie Down Bolts, removable. 2 pair. $10 pair.
Locost radiator, Hyundia alu radiator, used 200 miles. $30
Taylor Made RAC CGB clubs, R7 woods, Burner Driver, Rescue Wood, Ping putter, regular RAC sand wedge, bag, balls, many Titlist etc.. First $350. I don’t have patients to part out. Irons appraised at $300. Very rare, outstanding compromise between perimeter weighted and blades. Carbon shafts.
Polar FT1 heart rate monitor. Used once. $10
Stock Car racing Spoiler. Alu. 2pc. 88 Monte Carlo Late Model. Some sharpie markings but no holes, great shape… $20
Generic Mud Flaps. Free if you buy something else.
Locost Racing Fiberglass seats. Pair, narrow. Bottom mount. Not perfect. Bed liner on backside. $70 each or $120 for the pair.
3” x 3ft. Stainless muffler pipe $10
Fluorescent Green Wheel Paint Kit. White Primer, 3 cans Grn, 2 cans Clear Wheel Coat. $46 value.
GM Corvette LS3 fuel rail. Stock w/clips $30
GM Corvette LS3 intake cover, plastic with foam insulation. Great to paint match while keeping your stock. $20
7.5/7.625 GM Clutch Type LSD 28 Spline, with Yukon install kit, bearings, shims, crush washer and shim crush washer replacement. First $50.
Honda side marker lens housing only 2ea. $10 pair
Drift Bible DVD and Best motoring Drift DVD, Drift How To Book, Plus a bunch of DSport DVDs with lots of cool tuner cars and drift action. $40
Energy suspension 9.8105R swaybar bushing kit. $10
Miata Sway Bars, early. Free if you buy something else.
8”x12” carbon hood, roof vent. Wet carbon lay. $20
Braile no-weight 82015 15lb battery with mount. $40. Not enough to hot start since new cam install.
Moroso hood pins, aluminum. $10
Add-a-hitch kit. Complete kit, easy to add bike or carrier mount to front bumper or trailer frame. $15
¼” throttle linkage 2ea. Aluminum. $10 for both.
Hawk brake pads. Dynalite 1C183 Perfect for miata. Used about 1k miles. Not soft enough for cars under 2k lbs. Pair, 2 drivers side, 2 pax side. $10
Booster seats, Great shape. 2ea. $10 for pair.
ARP 12mm 1.5 wheel studs, 100-7708 GM press in. 2 pair. 10 total. $10
OBX Silicone 4” intake coupler with buldge. New. $10
3” side pipe mufflers, non-glasspack baffle style, includes alu caps ($45) $20 pair. Mild steel with ceramic coating.
3” muffler clamps. $5 pair.
1 3/8” stainless u clamps. $5 pair.
How narrow is "narrow"? By "not perfect" are we talking scratches and "use", or are we talking cracks and "defects"?
They are like 14.5" They are pretty flimsy/cheap and the mounts not perfect as seen in photos. I have 2 others ahead of you guys, so will let you know if they don't pan out.
bonjo2@gmail dot com gets pretty quick reply. I can no longer access this site from work.. Doh.
The seat sales fell through. Local pick-up or near local delivery only.
I am in New Cumberland/Harrisburg PA area. I visit Hampton VA a couple times each month, so can arrange a drop off en-route.
Ted's got the seats.
I just realized I still have a pair of 10" stalker rear arches, and 12" Birkins.
Trying to free up funny money for a new LS oil pump, LS3 exhaust, and windshield.
If I sort out the windshield, brooklands will go too. I love them, but ever since the softball incident, need more safety for my pax and regular driving..
I can ship the radiator and other small stuff. But seats and arches and side-pipes too pricey to be worth the effort.
Best.
