MNlotus Posted December 21, 2013 Posted December 21, 2013 i am getting widetrack suspension on my car so i wanted to know if this quick rack would work with my car. http://www.demon-tweeks.co.uk/motorsport/suspension-steering/caterham-alloy-quick-racks On this site they have a 8 or 22 percent version. I do not want the 22 percent version, only the 8 percent. But when i click the 8 percent version it says they only have it available in the narrow track version. The widetrack kit i am getting says it come with steering rack extensions though, so would it work if i got the 8 percent rack with the narrow track version but added the steering rack extensions? here is the widetrack i am getting… http://www.demon-tweeks.co.uk/motorsport/suspension-steering/caterham-widetrack-front-suspension-kit
drew... Posted December 22, 2013 Posted December 22, 2013 MN Lotus - I have the wide track front on my Caterham. The only difference between the standard and the widetrack in the steering is a spacer between the tie-rod end and the steering rod coming out of the rack. Otherwise the rack and pinion steering is toatally interchangable. -drew...
dallasdude Posted December 23, 2013 Posted December 23, 2013 (edited) They made a 8% left hand drive wide track rack, but I think it has been out of production for a while. The part # is on the bottom of the rack. I had it but can't find it now, but yes you can use the normal rack with the extenders. I believe my early 2000 car came with and 8%, the 2002 with a 22% both from the factory kit. You might want to order a couple of the bump steer shims that go under the rack while you are at it. Pretty easy to make out of aluminum strip also. Edited December 23, 2013 by dallasdude
