Gherkin Posted January 11, 2014 Posted January 11, 2014 (edited) Set of four flow matched 60 lb/hr Siemens Fuel Injectors for Duratec engines (not sure about Zetec). The flow rate of this set was matched to within less than 1% variance. The industry standard is +/- 3% so total variance can be as much as 6%. These injectors are equipped with an EV1 style connector and I am including adapters to connect to EV6 type if the factory Ford harness is being used. 60 lb/hr injectors at 43psi fuel pressure will support 375 HP in a NA 4 cyl. engine (320 HP forced induction). These injectors are used but only for a short time, less than 5K miles. They were removed from a professionally built and maintained 600HP Mustang (the owner is going for 900HP!). I am familiar with the car they were removed from and the very reputable shop building it. I purchased a set of eight injectors removed from the car (he's a V8 guy so he had no need for 4 left over units) for $300 but only need four of them. $150 for set of 4 with adapters shipped via USPS Priority Mail. Chris Edited February 16, 2014 by Gherkin
Gherkin Posted January 25, 2014 Author Posted January 25, 2014 !!Price update!! I need to free up some cash for a tune:rolleyes:! Reducing the price to $100 for the set with adapters and shipping, now that's a deal:hurray:!!!
