Suzuki Swift GTi motor and Samurai transmission set up F/S
OK, here is what I have: Clean 1993 Suzuki Swift GTi motor with ECU (unknown mileage or condition), wiring, flywheel, and yellow powder coated valve cover. New, complete, GTi gasket set. Samurai 5 speed transmission (unknown mileage or condition), Samurai flywheel. Factory GTi service manual. Aftermarket Swift and Samurai manuals. Samurai short drive shaft (goes between the transmission and the transfer box). GTi tubular racing exhaust header. I have well over $1200.00 invested in all this. I have tried to rotate the engine every month but I would think it would need an overhaul because it has sit so long. There are several large boxes of STUFF so shipping would not be cheap. I could bring it to the Se7ens Gathering near St Louis I early June that I am in charge of and you could pick it up there which would save a lot in shipping plus you could see all the cars. I will not take less than $1000 for the complete package plus shipping. Let me know soon before I put it out on fleabay. Russ
I just remembered I have a Ford EDIS ignition with trigger wheel and a set of Kawasaki 600 bike carbs I will throw in to sweeten the deal, Russ
