plbs1234 Posted May 28, 2014 Share Posted May 28, 2014 I'm having trouble getting my 1986 Caterham with Kent crossflow to pass emissions. I replaced all the ignition parts and added an MSD ignition module. I also leaned out the DCOE 40's. This got me very close to passing, but I need to still get a little cleaner. Has anyone else added a catalytic converter to allow them to pass emissions? If so what converter did you use? Thanks, Paul Link to comment Share on other sites More sharing options...
Warren Nethercote Posted May 28, 2014 Share Posted May 28, 2014 Won't the success of a cat depend on why you are failing emissions? If the failure is for the right reasons, then shouldn't almost any cat for a similar sized engine do the job? If you want 'off-the-shelf' then Birkins have a cat available, as would, I assume, Caterham. Link to comment Share on other sites More sharing options...
