YSILVERCS Posted June 20, 2014 Posted June 20, 2014 Hi Guys, I am looking for wide wheels for my 1968 Lotus 7 S3 like the ones in the photos. I know they are probably Minilite (or similar) but although I approached a few specialists they could not identify the exact size of the wheels or provide relevant data (PCD, off set, ET). S3 series Lotus 7 is similar to a Caterham s3 (Classic) so the wheels should fit my car. I will Appreciate any help. Yaron
TheDingo8MyBaby Posted June 20, 2014 Posted June 20, 2014 PCD is 4x4.25. That I can tell you for certain. I can also tell you the wheels on the green car are panasports for certain and the red car has some off-brand panasport/minilite type wheel. The rest of my response will be speculation. I have done some measurements on my caterham and have done some work designing and working with wheels of similar size, so I believe it to be informed speculation. The wheels on the green car appear to be 13x6.5 or 7 with approximately a 0 (possibly slightly positive) offset. There are more photos of this car here: http://www.themotoringenthusiast.com/caterham-7 The wheels on the second car appear similar to the ones on this car: http://usa7s.com/vb/showthread.php?t=7609 according to his spec sheet, they are 13x7" wheels. I believe them to be slightly negative offset. In order to be certain they will fit, you should probably measure your car. Not all 7 fenders are created equal.
Toyotus 7 Posted June 21, 2014 Posted June 21, 2014 Shelby also made a very similar wheel. The Shelbys I have look like a minilites with a sandblasted centre. 13 x 6, with 4x114.3 bolt pattern, but wider versions were likely made at one time. Mine are from the early 80s.
YSILVERCS Posted June 21, 2014 Author Posted June 21, 2014 Thank you guys for the usefull information. I found out that the wheels on the red car were provided by Chris from "Seven and Elans". Already contacted him.
