Everything posted by JohnK
It's about convenience. You can easily convert the car's energy into ft-lbs (if you'll allow an old-timer his habits) and when you go to calculate what the brake system has to generate to equal the energy of the car, it's all in the same units, and it's easy/natural to view the wheel with the brake parts as a torque. And then you multiply what the wheel and brake pads deliver by their coeficients of friction. It just saves a lot of thinking to work in the same units across the calculations and avoid errors in conversion factor arithmetic. Most software offers easy conversion into what's the unit that helps you vizualize the problem (but then, I was trained as a Biologist.)
To complete the thread, see http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=101568#post101568 which got stuck somewhere else.
Way back in http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97616#post97616 I went through theory and practice of what, on the face of it, is a straightforward matter of rolling one's own brake system. While the physics are just a matter of applying the relevant physics, the barrier to success finally came down to understanding the properties of brake pads that have not been "cured" as production pads are. The combination of a light car and race-car brakes makes it very difficult to get the brakes hot enough to bed them in - to drive off the compounds present in un-bedded or un-cured pads that keep the pads from developing the friction they're designed to deliver. What the manufacturers do to the production pads you buy at NAPA is cure them in commercial temperature and time controlled ovens, applying a schedule that their engineers/chemists have determined does the job. What you're supposed to do when you can only get un-bedded pads is generate that heat by doing a schedule of progressively harder stops - IF you have car that's heavy enough, which you can determine via the physics involved in the design of the brake system. If you have a very light car, you have a problem. . So, plan B was to get the pads hot by other means and I decided to use a hot-plate rather than an oven. I found a commercial-grade hot plate for a reasonable price* and set to work. With a bit of experimentation and some patience, this approach proved itself productive and revealed that the schedule of heating was not simple. Still I came up with vastly improved behavior in the brakes. First trial showed me that the fumes that come off the pads when they're being heated will not only make you sick, they'll damage the skin in you respiratory system. I had an awful cough for weeks. I had a good electronic thermometer that allowed me to see what temperature I was working with. With the pad face down, the temp at the highest setting and the pad lifted 0.020 off the heating plate with a piece of wire, I could see 450-500 F on the steel backing plate. I made a wind shield to go around the heating plate with a cylinder of roofing flashing. At the highest temperature, roughly 750 F on the plate, 2 hours heating improved the grippyness , a second 2 hours made a bit more, .. and I decided, Hell, the specs for the pads show that they still make friction a 800 F so I of the flipped the pads over so the backing plate was on the heating plate and let it heat for 6 hours. The color of the pads was much lighter, like Carroll Smith says they're supposed to be - and when I picked up a pad I found that this heating treatment had killed the cement that holds the pad to its steel backing plate and the two fell apart. So with a new set of pads I went back to pad face down supported by 0.020" wire, wind shield/chimney around setup, and heat at full tilt for 2 hours, 2 iterations. . When first installed after heating, the brakes were initially weak but became progressively stronger as they were used hard, and they stayed that way - probably an initial conforming thing between the pads and rotors. After this initial period the behavior stayed the same. Now the brakes show a progressive increase in strength as they get warm but the initial strength is, given firm pressure on the pedal, acceptable - but I don't expect to be able to lock up the wheels when they're cold. Modest use when enjoying the twisties makes them grippier. If you're driving fast and doing a lot of braking, the brakes become very strong and are very controllable with only light pedal pressure. I may get another set of pads and try a longer heating schedule, but as is they're greatly improved from the hazard they were when first fitted. Overall, one has to keep in mind that, without vacuum assist, even wonderful brakes don't give you initial grip like you get in a daily driver - as a demonstration pinch off the vacuum connection to that big tank (brake booster) that fits on the end of your master cylinder and see what it feels like. * http://www.burkett.com/Waring-WEB300-Electric-Hot-Plate-p/war-web300.htm
Other than the price, this looks pretty good - especially the ease of implementing it. Alternatively, I will add that I went through the work of designing, fabricating and installing an in-tank, sump system and have NEVER had any fuel starvation or plumbing or space problems, including one episode where I limped home barely running due to low fuel (bad fuel gauge) and found I had perhaps a cup-full of fuel in the tank. If anyone's interested add a post to this thread and I'll post a link to pictures - or maybe add it to my thread on this list.
Way East of Cincinnati on US 52 past Ripley, also there's some interesting stuff on SR 125 past Georgetown, east out to West Union and beyond. Also SR 32 to the East around Peebles and onwards to Jackson, and Athens if you're ambitious. It's been a while but old 32 East of Peebles was a real delight. Some ways past Peebles the new 32 climbs a little bit of mountain and the other side of it is some off northern Appalachia, bits of which that carry all the way to Athens. Careful on the back roads though, it's Combine season and those suckers are wide! Also, be real careful about spreading the word - the good roads I used to enjoy on my Ducati Diana got invaded by bunches of sport bike canyon racers and the locals turned real hostile, with good cause. Se7ens seem to have a natural charm that calms people down, and being real courteous when around others helps a lot, and I haven't seen any hostility. Be safe!
Not alone in this I'll guess, I explore local roads away from the city looking for stretches that are twisty, hilly, low traffic and as deserted as possible. After a productive few hours last week I put in at a local town for food and some fuel. While gassing, up this tall kid, probably a year or three out of high school walked over to have a look and a chat with the usual questions. After I filled him in about some of the wonders of Se7ens and he was telling me he'd keep an eye out for me in the future, a friend of his called over and interrupted. He turned around and called back to his friend, "I gotta get going, I have to brand some steers." Guess I managed to get far enough away from the city. I'll keep an eye out for him too, maybe I can pick up a new skill set.
Modifications: ---------------------------------------- This is the front mount structure installed. View of the cockpit from the left side of the car: https://www.dropbox.com/s/4lkfmqm7v1qgrmi/Diff_front_fix_overview.JPG?dl=0 . The yellow zinc plated bolts identify the connections which tie front of the differential-enclosing shell (the nose of the shell) to the chassis. Note the front of the driveshaft tube's absence of paint. The car was run for a couple thousand miles with the 'as delivered' front mounting of the differential, and the paint was rubbed off of the front of the driveshaft tube as the differential moved around in the driveshaft tunnel (rubbing against the driveshaft loop and/or my handbrake fittings). Seeing this when I took things apart in order to replace the differential with one that had the correct ratio convinced me that I'd better undertake this fix if I valued the well-being of my right thigh, not to mention expecting the drive train to stay in place as I drove the car. Preparatory to this I had the driveshaft redone by a local commercial driveshaft place. The rear universal was bad (in all of the THREE successive units which I received from the “kit's” builder), and the driveshaft had not been balanced (the driveshaft place showed me the evidence). “Spicer” (see later shot) makes equipment specialized for balancing driveshafts which the shop used. I disassembled, cleaned, re-lubricated with CV joint grease, and reassembled the CV joint connected to the transmission's tail myself – the innards were filthy (water+grease), but the surfaces turned out to be OK (rust had not yet set in, nor had grit been ingested). If Honda had put a u-joint here as well as at the far end you'd feel a pulsing with each driveshaft rotation as the car cruised at a steady speed when there was any angularity in the driveshaft. The effect may be subtle but contributes to the overall feeling of soundness/quietness of the car. All front-wheel drive cars have these expensive-to-manufacture joints on both ends of each of their half driveshafts – which usually run at considerable angle to their transmissions. Otherwise the sound/vibration/pulsing would be really annoying, not to mention being hard on the mechanicals. Back to this picture: Above and below the driveshaft are the bonded bushes fitted with 1/2-20 Grade 8 bolts (Thanks be to W. W. Grainger for stocking these in packages of fewer than 100) and which connect the chassis and the front of the differential shell through the vibration-absorbing bushes. - The base which receives the lower mount's bonded bush is tied to the chassis tubes beneath it through vertical 1/8” plates welded to these chassis tubes, which are tied to the mount base with allen head cap screws (what you see in this picture is one of these plates welded vertically to the chassis – the mount base is trapped inside this/these plates). The top part of this lower mount is tied to the shell by vertical nut-plates which receive allen head cap screws through the shell. So the upper part of the lower mount encloses and thus stiffens the bottom and sides of the front of the shell (the 'nose') as well as tying the shell to the chassis via the bonded mounts (see following links/shots for details). - The top bonded bush is bolted to a boss welded to the top front of the shell. This boss is reinforced as shown in later links/shots. (Yes, the front part of this mount is indeed sawed through on one side. I got the whole thing done and then realized that that's where the handbrake assembly goes!) - Toward the rear, a single bolt head can be seen at the lower edge of the shell. This is one of the four bolts used in the two brackets which tie the differential to the shell, greatly stiffening the shell around the differential and tying the two together rigidly. See following pictures. Overall this treatment is designed to both make the shell much stiffer (more like an egg shell) and to feed the loads that occur at the front of the differential into the chassis while handling shock in a way that an engineer would approve of (and which wouldn't contribute to this sub-system's early death). The bonded bushes are very strong and absorb shock to the chassis as torque goes through the drivetrain to the wheels. This was hard. The bonded bushes are pulled into place as they are bolted in (they go from mushroom to dumbbell shape as their central bolt is tightened) meaning everything has to be lined up exactly – since the top mount is going into a threaded boss, the danger of cross-threading (and ruining the whole shell assembly) is high. Many careful preliminary attempts and tests here avoided disaster, or at least having to buy a new shell and having to do all the work over again. Following shots show the components. Differential lower front mount. . Complete assembly supporting the open end of the front of the shell and providing the attachment to the chassis at the bottom of the shell: https://www.dropbox.com/s/kuvov9xi35n3rgy/Diff_front_lower_mount_assy.JPG?dl=0 . Detail. https://www.dropbox.com/s/eerrritev6hbz03/Diff_front_lower_mount_assy_detail.JPG?dl=0 . Installed in chassis. https://www.dropbox.com/s/094yf05mee7iwdi/Diff_front_lower_mount_install.JPG?dl=0 . Modification of front of differential-supporting shell, upper mounting. A and B shots: https://www.dropbox.com/s/64bv94pwlvs8yxm/Diff_front_upper_mod00.JPG?dl=0 https://www.dropbox.com/s/xp120rd1ybnxl84/Diff_front_upper_mod01.JPG?dl=0 . Installation of Subaru brackets (above, item (6) and the T4 attaching bolts) which bridge the open/lower part of differential-supporting shell to the differential. This along with item (2) turns the shell into a rigid enclosing structure around the differential. A and B shots: https://www.dropbox.com/s/5ozsgf7ekt1xpaq/Diff_ShellMod_shell-to-diff_bracket_01.JPG?dl=0 https://www.dropbox.com/s/rw3ax6orkna1gt9/Diff_ShellMod_shell-to-dif_bracket_02.JPG?dl=0 (that bit of wood in this last shot is the cane I was using to get around when I was doing this work while I was waiting my turn to have a hip replaced.) These two shots really make it obvious how asymmetric the drivetrain is – and why the axle half-shafts are different lengths – and why an owner of an S2K has to spend lots of time ensuring that all four wheels are exactly at all of the four corners where they're supposed to be when doing the alignment, along with ensuring that the axle bearings aren't binding as the axles move through their range of bump/droop (easy to get bind through compression here, or have the axles pull out of the differential when things move – the latter is embarrassing, the former is expensive). If you spend a little time thinking about all these connecting pieces, it becomes clear that the builder seemed to think that all the power that the engine produced was going to magically go right to the rear wheels without having to worry about how the wheels were going to connect that power to the chassis. Return to home: http://www.usa7s.net/vb/showthread.php?7421
With respect to the Subaru differential that was included and delivered mounted in my 'kit's chassis, I've assumed a couple of things. First is that Honda knows how to engineer powertrains (engine+transmission+differential) that provide the driver with optimal performance, and that this involves optimizing the engine's torque curve via the gear ratios of the transmission and differential. Second, Subaru engineers have a good handle on mounting their drive train components in their chassis, including those in their over-the-top rally cars such as the Impreza WRX (not the STI) which is what the differential I got was engineered to work in. - First, the differential itself. The Honda S2000 engine is, in absolutely stock tune, a very high performance engine, so saddling it with a sky-high 3.54 differential (which is what my 'kit' showed up with), when Honda determined that a 4.10 ratio is what matches the output characteristics of it and it's transmission, is stupid and unless one wanted to waste such an extraordinary engine-transmission by lugging the crap out of it all its life, it needed to be changed. . I found out that, with one exception, there is no junk yard that will deliver what you ask for when it comes to Subaru differentials (the one exception actually admitted that it could find no sourcing yard that actually had this item in the spec requested, and apologized – the other yards just tried to pawn off whatever they could get their hands on in the hopes that the buyer wouldn't know what they were getting). Subaru does indeed supply such a thing and after doing the homework and providing Subaru with the spec (Subaru Impreza WRX manuals: http://www.wrxinfo.com/service_manuals/ ), provided me with one and it came in exactly as ordered. They were pretty pleasant to deal with too, in contrast to all the rest of the yards. (I'll ignore feeling bad about how much it cost me to throw away what came in the kit I paid for.) - Second, mounting the differential in the chassis. Subaru engineered all of this : https://www.dropbox.com/s/adhzhj0mzh1iro9/Subaru_Diff_mount.JPG?dl=0 to connect the rear of its Impreza WRX drive train to its chassis. The builder of my WCM S2K 'kit' cut this up in order to fit these parts into this chassis. At the front of the shell (item (1)), the nose along with its wings was cut off and a boss was welded to the top front of the shell behind its hacked-off nose and tapped for a 1/2”-20 bolt. A rubber donut was put over the boss and a mounting plate on the chassis went over and around the donut and a 1/2”-20 bolt connected the two together. So this attached the front of the differential mount to the chassis instead of the wings. This turned out to be not strong enough (what a surprise!) and was found to twist apart in use, breaking the boss-to-shell weld and allowing the front of the differential to crash about in the driveshaft tunnel making awful noise and beating anything within its reach to death. https://www.dropbox.com/s/ghlp8tzcozw4xa2/Diff_Mount_Fwd_Pullout.JPG?dl=0 I wasn't about to trust this lame fabrication attempt with my brand new differential, or the driveshaft that I had to have fixed on my own to replace the junk u-joint in the driveshaft that showed up in my kit, not to mention the future well-being of my right hip and leg. To fix this I made three changes: . I fabricated a structure that duplicated, in smaller extent, the wings and nose of the shell originally designed by Subaru to support the input end of the differential; . I created a support (a 'nose') around the front of the differential-supporting-enclosing shell to strengthen and stiffen the shell to deal with rotation, and vertical and horizontal forces the differential generated, and attached this fabrication (at upper and lower points) to the chassis with a pair of very stout industrial bonded bushes (i. e. I created shortened wings and positioned them vertically instead of horizontally); . I also bought the stock Subaru lower shell supports to tie the shell to the differential at the shell's open part on the bottom (item (6) in the drawing). These supports makes the shell a lot more rigid and ties the differential rigidly to the shell. Details follow. I don't know how serious a thrashing my fabrication is strong enough to take, but it's gotta be vastly better than what showed up in my driveway on my birthday in 2006. Also, because the differential's entire support system is attached to the chassis both fore and aft via heavy bonded bushes, shocks from the drivetrain to the chassis are damped so the car is a lot quieter and fatigue failures must be reduced. I'm trusting that, since the load-bearing advantages of the stock Subaru design can't be implemented because of the lack of space, this weakness may be offset by the much lighter weight of the entire car, and this configuration imposes lower loads on the drivetrain. (At least that's what this fool hopes.) Rubber bushes bonded to steel are used in many support structures in industry. I found the following family of mounts at: http://www.hutchinsonai.com/products/product.cfm?cid=1&fid=5 and details of their sizes and ratings at: https://www.dropbox.com/s/vjd3xugl6uj0a3x/Barry%20Bond%20Series.pdf?dl=0 Scroll down to see the drawing that shows how this type is installed (basically it's installed as what looks like a mushroom, and then compresses when bolted together into dumbbell shape. The end result is that the two pieces -the chassis and the differential- have a heavy layer of isolating rubber trapped in compression between them where they connect to each other). And scroll down to see the dimensions and load ratings for BC-1122-4 which is what I fitted. (Subaru uses a similar construction at the rear.) The two different ratings for maximum load in each size range are due to differences in the durometer of the rubber used in each part. Part Two: the implementation: http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97621#post97621
. With respect to the Subaru differential that was included and delivered mounted in my 'kit's chassis, I've assumed a couple of things. First is that Honda knows how to engineer powertrains (engine+transmission+differential) that provide the driver with optimal performance, and that this involves optimizing the engine's torque curve via the gear ratios of the transmission and differential. Second, Subaru engineers have a good handle on mounting their drive train components in their chassis, including those in their over-the-top rally cars such as the Impreza WRX (not the STI) which is what the differential I got was engineered to work in. - First, the differential itself. The Honda S2000 engine is, in absolutely stock tune, a very high performance engine, so saddling it with a sky-high 3.54 differential (which is what my 'kit' showed up with), when Honda determined that a 4.10 ratio is what matches the output characteristics of it and it's transmission, is stupid and unless one wanted to waste such an extraordinary engine-transmission by lugging the crap out of it all its life, it needed to be changed. . I found out that, with one exception, there is no junk yard that will deliver what you ask for when it comes to Subaru differentials (the one exception actually admitted that it could find no sourcing yard that actually had this item in the spec requested, and apologized – the other yards just tried to pawn off whatever they could get their hands on in the hopes that the buyer wouldn't know what they were getting). Subaru does indeed supply such a thing and after doing the homework and providing Subaru with the spec (Subaru Impreza WRX manuals), provided me with one and it came in exactly as ordered. They were pretty pleasant to deal with too, in contrast to all the rest of the yards. (I'll ignore feeling bad about how much it cost me to throw away what came in the kit I paid for.) - Second, mounting the differential in the chassis. Subaru engineered all of this : https://www.dropbox.com/s/adhzhj0mzh1iro9/Subaru_Diff_mount.JPG?dl=0 to connect the rear of its Impreza WRX drive train to its chassis. The builder of my WCM S2K 'kit' cut this up in order to fit these parts into this chassis. At the front of the shell (item (1)), the nose along with its wings was cut off and a boss was welded to the top front of the shell behind its hacked-off nose and tapped for a 1/2”-20 bolt. A rubber donut was put over the boss and a mounting plate on the chassis went over and around the donut and a 1/2”-20 bolt connected the two together. So this attached the front of the differential mount to the chassis instead of the wings. This turned out to be not strong enough (what a surprise!) and was found to twist apart in use, breaking the boss-to-shell weld and allowing the front of the differential to crash about in the driveshaft tunnel making awful noise and beating anything within its reach to death. https://www.dropbox.com/s/ghlp8tzcozw4xa2/Diff_Mount_Fwd_Pullout.JPG?dl=0 I wasn't about to trust this lame fabrication attempt with my brand new differential, or the driveshaft that I had to have fixed on my own to replace the junk u-joint in the driveshaft that showed up in my kit, not to mention the future well-being of my right hip and leg. To fix this I made three changes: . I fabricated a structure that duplicated, in smaller extent, the wings and nose of the shell originally designed by Subaru to support the input end of the differential; . I created a support (a 'nose') around the front of the differential-supporting-enclosing shell to strengthen and stiffen the shell to deal with rotation, and vertical and horizontal forces the differential generated, and attached this fabrication (at upper and lower points) to the chassis with a pair of very stout industrial bonded bushes (i. e. I created shortened wings and positioned them vertically instead of horizontally); . I also bought the stock Subaru lower shell supports to tie the shell to the differential at the shell's open part on the bottom (item (6) in the drawing). These supports makes the shell a lot more rigid and ties the differential rigidly to the shell. Details follow. I don't know how serious a thrashing my fabrication is strong enough to take, but it's gotta be vastly better than what showed up in my driveway on my birthday in 2006. Also, because the differential's entire support system is attached to the chassis both fore and aft via heavy bonded bushes, shocks from the drivetrain to the chassis are damped so the car is a lot quieter and fatigue failures must be reduced. I'm trusting that, since the load-bearing advantages of the stock Subaru design can't be implemented because of the lack of space, this weakness may be offset by the much lighter weight of the entire car, and this configuration imposes lower loads on the drivetrain. (At least that's what this fool hopes.) Rubber bushes bonded to steel are used in many support structures in industry. I found the following family of mounts at: http://www.hutchinsonai.com/products/product.cfm?cid=1&fid=5 and details of their sizes and ratings at: https://www.dropbox.com/s/vjd3xugl6uj0a3x/Barry%20Bond%20Series.pdf?dl=0 Scroll down to see the drawing that shows how this type is installed (basically it's installed as what looks like a mushroom, and then compresses when bolted together into dumbbell shape. The end result is that the two pieces -the chassis and the differential- have a heavy layer of isolating rubber trapped in compression between them where they connect to each other). And scroll down to see the dimensions and load ratings for BC-1122-4 which is what I fitted. (Subaru uses a similar construction at the rear.) The two different ratings for maximum load in each size range are due to differences in the durometer of the rubber used in each part.
My particular car was delivered with a perfectly fine limited slip differential built into a 5-link rear suspension, but it had an absolutely terrible ratio and was mounted in the chassis in a really awful way. This explains how I dealt with these problems. Due to length, this is explained in the following two posts. The starting point and the design: http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97620#post97620 The implementation of the fix made to the front of the differential mount: http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97621#post97621
. How I approached and fixed my very evil oversteer problem. My posts in this thread are in sequence, but are embedded in a thread dedicated to a general discussion of handling. This thread (Handeling (sic) Thread) starts at http://www.usa7s.net/vb/showthread.php?9243-Handeling-Thread& My collection of posts starts at http://www.usa7s.net/vb/showthread.php?9243-Handeling-Thread&p=80768#post80768 and ends in the Handeling-Thread at http://www.usa7s.net/vb/showthread.php?9243-Handeling-Thread&p=94723#post94723
. I seem to have found a brake problem that's common to Se7ens and is due to their light weight. All the after-market brake systems I know about require new pads to be “bedded in”. If this isn't done, the brakes will be weak due to what's known as 'green fade', and this fade shows up as a lack of instant 'bite' when the brakes are applied as well as overall poor stopping ability but can improve dramatically once the brakes get hot. Bedding in is accomplished by getting the pads hot enough to drive off chemicals created in the manufacturing process that keep the brakes from working like they should until they're hot. This is very hard to do if the car is light. . The following post describes this phenomenon and the process. (The link below is to the thread's post #6, which is the result of my rewriting the first post to make it more understandable and spell out what's happening more concisely.) Start of the "weak brakes" thread: http://www.usa7s.net/vb/showthread.php?10484-Weak-brakes (This is a long thread with lots of discussion. If you want to skip to the conclusion of the "weak brakes" thread go to http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=101568#post101568 and you can ignore the rest of this paragraph. The following stuff is interesting if you can find information useful to you in a similar situation.) (Note that this hasn't been completely resolved yet - it's turning out harder than I thought to get the brakes over 300 degrees F, even when pulling down several times from 120 MPH. Stay tuned.) January 2016: Over the winter of 2015-16, and prompted by something Wilwood suggested, I'm working on making covers for the front calipers to keep them from shedding heat which the do really well, hanging out in the air stream like a formula car and all. Time spent at the dragstrip doing runs to warm up the brakes and then pulling down from 120 MPH several times and then letting the car rest showed less than 150 degrees F. when measured directly at the caliper with a thermocouple bolted to a caliper and connected to an electronic thermometer. Along with covers for the calipers I'm planning on plugging the entrance to the cores of the rotors so the vents won't flow air. That along with the covers, 'specially over the slot at the top of the caliper where you can see the rotor and its vanes, should get me some heat staying in the caliper. Who was it said that this was supposed to be easy? N.B. that, when the brakes were warmed up, they worked extremely well - very modest pressure on the pedal put you in the area where wheel lock-up was not far away and the feel was excellent - coming down from 120 MPH I could keep the front tires at the point of chittering (?) all the way down to low speed gassing myself on rubber fumes in the process. . To remind me of the goal here, the brakes should do this when they're cold, just like the brakes in my Civic do. That's what bedding in is supposed to achieve.
I remember reading about people fitting electric power steering to their cars. I've also read reviews saying that electric assisted steering delivers poor feedback. I know that Honda's been criticized for delivering Civics and Fits with numb feeling steering allegedly caused by their electric power steering lately, and statements that electric power steering in general provides poor feedback compared to either manual (no question) or hydraulic (requires a setup designed for racing, rather than production/street parts adapted for re-use in a sports car). Making it more confusing still, currently Porsche uses an electric steering assist system while Ferrari uses hydraulic, but I'll bet the Porsche system would run you more than the hundred bucks I've heard mentioned and wouldn't even be willing to guess what Ferrari does with its hydraulics – anyone have experience with Moog's electrically controlled hydraulic valves and the computer programs necessary to manage how it behaves? Also regarding Honda's choice of electric over hydraulic here, the energy savings of the former are huge in comparison to the latter, so this may figure significantly in their decision making. It's worth noting that not only is the rack I used designed from the ground up for racing applications, the 3 HP pump that delivers the oil to drive the rack is also designed specifically for racing applications. These are very specialized pieces of equipment, and it shows in the way the steering effort disappears when you're driving fast and very quick and ultra precise control becomes effortless. Also read http://www.usa7s.net/vb/showthread.php?9243-Handeling-Thread&p=80842#post80842
I found one compelling reason to analyze and eventually redesign the steering on the 'kit' I got and wound up with something that works better than I could have imagined. http://www.usa7s.net/vb/showthread.php?7989-A-note-on-steering Also, here's a collection of pictures showing how to mock up a steering system in order to, first of all, place the rack accurately in the chassis so you can then determine where it actually needs to be in order for it to work right, and along the way determine the dimensions of all the parts that comprise a rack. https://www.dropbox.com/sh/8qlli08y8zfftua/AABtEyYGIUK0EmclUVFOwMNha?dl=0 Also, there were some comments on fitting electric assisted steering. See http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97615#post97615 for some notes on this.
Sections covering work not described in the first write-up or after getting the car on the road: On Steering: http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97614&posted=1#post97614 On Brakes and what it takes to make them deliver what they're supposed to: http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97616#post97616 On Handling (fixing an evil oversteer problem): http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97617#post97617 On the last component in the powertrain: http://www.usa7s.net/vb/showthread.php?7421-Ithaca-Lemonade&p=97618#post97618 Preamble (read this to see why I went to all this bleeping trouble). I put this thread together to pass on my experiences and share what I think I've learned as I turned my 'kit' into a car, a car that's not only sound and fun to drive, but actually deserves to be called a 'Se7en'. I hope readers will appreciate that: - this is one person's take on what Se7ens are about, - my view is based on what one builder delivered, and claimed it qualified as a Se7en kit, - a Se7en can be any number of things, depending on the driver's expectations, which can change as the driver/builder/tinkerer gains experience. . What THIS driver happens to be focused on is what a Se7en DOES when you drive it. A Se7en should be an invisible link between you and the road. If the car has to be wrestled through the twistiest parts of the road, then it is not a 'good' car and it doesn't deserve to be called a 'Se7en'. . A Se7en really is a thinly disguised race car that can be legally driven on the street (if you're careful). Happily, we have examples of what a 'good' race car is in the reports of what 'good' race cars do in competition, and to those with mechanics' chops, what's involved in actually making race cars that folk think of as 'good'. The best description I've found of what a good race car IS, is in an article by Robert Cumberford on the OSCA MT4 appearing in the August 2011 issue of Automobile. http://www.automobilemag.com/features/news/1108_giant_killer_osca_mt4/ I still get chills up my spine when I read Cumberford on Bugatti, OSCA and Lotus, and feel very fortunate that I'm able to take part in this kind of experience with something I've been able to build and develop myself, and that aspires to delivering the kind of behavior I read about. As far as actually MAKING a 'good' Se7en, Carroll Smith runs down the 'from-the-trunk-of-the-tree' fundamentals in his “Prepare/Tune/Engineer to Win” series of books. Every time I re-read a section in one of his books I get a better understanding of how the different systems in a race car are supposed to work and, for a person building such things themselves, how to do it right. . My first/introductory post (http://usa7s.com/vb/showthread.php?t=7421) includes some threads that describe the work involved in first getting the car on the road. From here on are threads describing work done after I put 'release 1.0' on the road and saw what else had to be done to make it 'right'. What I've found interesting is that doing all of this has taken place on so many different levels. Some of it involves mathematics, some insight, some purely matters of mechanics, techniques and procedures . . . You can read, learn and study all about, say, suspension - but at some point you have to figure out how to select the materials and then develop the skills to fabricate and assemble things into parts that perform the task you've intend that they should do – and also find some way to verify that the things you've made are actually delivering what you intended. And when you integrate the collection of systems you've created into a car that actually delivers what you want, it's quite a trip. To get some perspective on what other people have brought to bear on the problem of creating a 'Se7en', you might refer to my post http://www.usa7s.net/vb/showthread.php?3533-Another-thing-to-consider-when-choosing-a-Seven or just go to the post that my post references: https://www.dropbox.com/s/edccxybb5nq2pgr/oconnell.pdf?dl=0 The take home here is that a current Caterham is the product of a lot of development done by skilled and talented folk that's taken place project by project over many years starting with the original Lotus 7. Such things just don't happen by accident, and there's no rule-book to follow that tells you what to do. Return to home page: http://usa7s.com/vb/showthread.php?t=7421
To simplify the issue ( and not spend the evening re-teaching a section from the average Physics text ) I'll quote a page from my favorite reference book, "BOSCH Automotive Handbook 5th Edition." From the section 'conversion of units', page 25: Units of energy (units of work) Unit.....|....J..... |....... kW . h..... | kp . m........| PS . h.............| kcal..................| ft-lbf..........| Btu............. | 1 J = ...|....1.....|... 277.8 . 10-9..| 0.10197 | 377.67 . 10-9 | 238.85 . 10-6 | 0.73756 | 947.8 . 10-6| Nett, you can express energy/work in a number of different units. I'll guess that Puhn chose lbf-ft because it simplifies the math he defined the brake system's operations in, and made understanding how you design a system to deliver a certain amount of stopping power easier to understand. He starts out by showing the difference in energy in a car at the top of a hill and then at the bottom, which is easy to understand in terms of lbf-ft, and the same unit makes sense when describing the force you can get from a caliper acting on a rotor - it follows nicely and doesn't involve a lot of unit conversions.
Lb-ft is indeed a measure of torque. It's also a perfectly good unit with which to measure energy. (My high-school physics teacher would be right proud of me - and Puhn too.) Also, in the context of brake system design, it's a very natural unit to use when you're sizing the components so that they accomplish what you want re stopping the wheel and are adding into the model equations the coeffecients of friction of the different bits, and when you've got enough torque to overcome the forces on the tire's contact patch, and so on.
Me too. I'd love to know the properties of the materials they use for their pads and rotors nowadays. Is there something beyond carbon rotors and ceramic pads nowadays?
Thanks for sharing your experiences. What you say is consistent with much of what I've learned in this part of my car-building adventure, and much of it is restated in the most current information I've found on the Wilwood site. Also, an understanding of some of what you write about can be gotten in revealing detail from a text covering brake systems, such as Brake Handbook by Fred Puhn. I think your comments might be especially relevant to someone who has an existing system and who's been attracted by some of the marketing to consider ways of making their car stop better. Reading through Wilwood's section on Pads (for example http://wilwood.com/Pdf/Flyers/fl384.pdf , http://wilwood.com/PDF/Flyers/fl227.pdf , and http://wilwood.com/BrakePads/BrakePadsApp.aspx) show that they are certainly making an effort to keep people from shooting themselves in the foot if they're considering different pads. If you take the time to read the material and think about what you'll be doing with the car, their recommendations make sense for the majority of situations. -------------------------------------- What I've written about addresses a special case that I've been wrestling with and applies to Se7ens in general. So it may be useful information to folk out there who have reason to fit 'grippier' pads, and may shed light on why their car's brakes feel weak in the first place, or are unsuccessful in getting different pads to work as they intended. The thing that makes Se7ens unique is that, for something that's driven on the street, they're very light. And as everyone who owns a Se7en knows, that means they can be tossed about on the road as if they were purpose-built race cars. When doing such driving one wants brakes that give appropriate performance, and that means 'grippy' pads that don't fade when pushed. If you're feeling that you need more/better brake performance, upgrading pads sounds like a straightforward thing to do. But in the case of Se7ens, lightness creates a problem. All of the aftermarket pads I know of have to be bedded in. If they're not bedded in they'll never deliver their advertised performance, and bedding in the pads is particularly difficult when the car is light. Thus you can install a set of pads and find yourself scratching your head wondering why they're downright awful when they're supposed to be much better than what you replaced. Here's how it works. At its heart, the bedding in process involves getting the pads hot through a series of progressively harder applications of the brakes at progressively higher speeds. This drives off the problem compounds within the pads that are created when the pads are manufactured. If the pads are new and you use them before they're bedded in, you'll experience what I've heard called "green fade": the pedal is hard, and high, all the parts of the system are all working as they should, but the car doesn't stop at all well. Bedding in makes green fade go away. Getting the pads hot. You're shooting for something over 300 F here, measured at the caliper - measure with a gun-type IR thermometer. If you've got a car that weighs 3,200 lbs or so, getting the pads to this temperature is not a problem. If you've got a 1500 lb car, getting the pads this hot is a problem. The physics that applies to brake system design gives a good approximation of how much heat is generated when you stop a car, and what the temperature rise will be in the car's rotors+drums (i.e., the elements that the pads act on to turn the kinetic energy of the moving car into heat so that the car stops). Looking at some values here: given two cars running brake systems which both run a set of rotors weighing 26 lbs, a 3,200 lb car braking from 90 mph to a complete stop dumps enough energy into its set of rotors to raise them 428 F. Doing the same thing with a 1,500 lb car raises a set of rotors that weigh the same 201 F. As far as pad heat range goes, this is next to nothing. Below are calculation results that show what's happening during braking to a stop from different speeds, and calculations that show braking to reduce speed such as you might do at the track. ----------------------------- To accomplish the bedding-in process for a Se7en, the car needs to be treated as teams do when they bed in the brakes of their race cars. Carroll Smith has a complete and clear description of bedding brakes in his Tune to Win on pg 81. Willwood describes much the same thing but for ordinary (i.e., heavy) cars in http://wilwood.com/Pdf/Flyers/fl384.pdf. In both cases it involves a non-trivial process, and in the case of a Se7en, involves speeds that make it necessary to be at a track go get it done. Smith cautions that the processes is difficult enough that a professional driver using practice time at a race track can fail to get a set of pads bedded properly, to the point where, as team manager, on race-day Smith would always carry a set of pads that he knew were bedded in properly in his brief case, just in case. Net, for a light car, the bedding-in is harder to do relative to a production car. So whatever level of performance you need from your brakes, you have to first bed them in. Regarding pad friction compounds, consider some choices offered by this particular manufacturer. Looking at http://wilwood.com/Images/BrakePads/compound_chart-2.jpg you can see that, for e.g., the BP-10 compound gives you good friction at low temp, an even change of friction over its temperature range, and you will see fade if you push hard. In comparison the BP-20 compound costs you a bit of cold friction but gives much better friction when used hard and a higher temperature maximum. Both compounds are very similar in other respects http://wilwood.com/Images/BrakePads/compound_chart-1.jpg Shows that all of these compounds start with much higher friction and deliver very high friction at very high temperatures - but Wilwood tells you that these are for competiton only and will shorten the life of the rotors significantly. When you add to this sort of thing to a very light car, i.e., a purpose-built road race car or a Se7en, you have to ask if you're going to be in the temperature ranges that the pad is designed to work in. You can run the race pads and get really great friction right off the bat and never have to worry about fade, but they're likely to be working below the range where they're happy and it'll cost you frequent rotor replacement. I'll guess that these are a bear to bed and bedding applies to the rotors as well as the pads. Looking at the calculation results below, a Se7en will have to be driven really hard to generate the temperatures where a competition pad is suitable. The numbers also say that, just the bedding-in requires that you get the car to at least 125 MPH, and even then the temperature is not all that high. Calculations ------------------- Temperature generated in a 26 lb set of rotors by a: 1,500 lb car coming to a complete stop from 90 mph = 200 F 3,200 lb car coming to a complete stop from 90 mph = 428 F For a 1,500 lb car, same rotor set: MPH................Degrees F 135 to 0..........452 (=452.00-0.00) 135 to 50.......390 (=452.00-62.00) 130 to 0..........419 (=419.13-0.00) 130 to 50.......357 (=419.13-62.00) 125 to 0.........388 (=387.51-0.00) 125 to 50.......326 (=387.51-62.00) 120 to 0.........357 (=357.13-0.00) 120 to 50.......295 (=357.13-62.00) 110 to 0.........300 (=300.09-0.00) 110 to 50.......238 (=300.09-62.00) 90 to 0............201 (=200.89-0.00) 90 to 50..........139 (=200.89-62.00) Physics: Kinetic Energy in lb-ft = ( Weight of Car in lbs x (Speed of Car in MPH)squared ) / 29.9 Temperature Rise of Rotors+Drums in degrees F = Kinetic Energy in lb-ft / ( Weight of Rotors+Drums in lbs x 77.8 ) The Brake Handbook by Fred Puhn spells out the physics and usage. While the material here is dated with respect to current product offerings, physics is physics. The problems I faced were a bit different since I started with a blank sheet of paper, necessary because the brake system that showed up with my kit was laughable. I set out with the goal of building a brake system that could haul the car down very quickly, and that it should do so with modest force on the pedal so that I would have good controllability. The system should not fade if put to heavy use, and the system needed to be sized to fit the car; I wanted the setup to work on a car with 13" wheels, which put some contraints on what I could do. After a lot of trials and head scratching, my "aHah" came about when I did the math to calculate how much energy the car was going to develop at speed and the rise in temperature that that energy would generate in the rotors when I used the brakes. Then I was informed by Wilwood that the pads needed to get to over 300 F , minimum, before they would bed. Disclaimer: I have no relationship with Wilwood or any other brake system manufacturer. My personal preference leans toward Brembo, but at Wilwood I found the components that fit my needs at a price I could manage.
Jim, Looks good and stout, and certainly does a good job of keeping the driveshaft from hitting anything other than the loop. But isn't the problem the fact that the driveshaft is being allowed to move around too much because something that's supposed to keep things in place is failing?
Protecting the bits that are within the reach of a flailing driveshaft can't be anything other than a good idea. Safety wire is substantial insurance, at the cost of figuring out how to drill G8 bolts for safety wire. How much to tighten is always a hassle. If everything is installed according to the Helm's book for the S2000 and it fails, I tend to look for something else causing a failure. I notice there are no plates underneath the heads of the allen screws and the allen screw sizes here went from 6 to 8 mm in 2004. Torquing these was a bear in my car and when I removed them to change diffs, they were all absolutely tight. The single-bolt front mount at the diff shell is known to rock and I decided to re-design this, and have done a page on it. I'm currently pulling all the stuff I've done to my car into an easier to follow form and it includes this page on the diff treatment, so stay tuned. Clearly your car dodged a bullet here. That CV joint isn't a light piece of equipment to be banging about in its tunnel.
Hi Loren, . Good observations and conclusions on your part, and I've tried just what you describe about warming up the brakes because I also saw that as a very sensible approach. And this should work because most pads increase their friction when they get hotter, but only in the short term. If you're driving on the street, the brakes will have time cool off and lose their friction. On the track you'll keep them hot. But as I've learned, bedding the pads in successfully will give you much much greater stopping power - and that power (bite) will be there without having to get the brakes warmed up. I wrote this because, after all the problems I've been having and all the different things I've tried and finally learned, I developed the suspicion that most people driving Se7ens of any sort put up with really lousy braking - because it's so difficult to properly bed in pads on a light car (and this especially includes race cars which can be even lighter than a Se7en). (When reading my post keep in mind that, as has been the case with my car, I changed things quite a bit* from what was shipped, but in this area I think the basics apply across the board.) It all comes down to the fact that you have to really heat up the pads a lot in order to drive off whatever stuff is in the pads that prevents them from developing the friction that they're supposed to deliver. At the end of the process, after you do a succession of many progressively harder stops from higher and higher speeds, when you do a final bonsai stop from high speed, an IR gun-type thermometer should show at least 300 degrees F when pointed at the caliper. Wilwood provides stuff to people who are mostly driving cars that weigh over 3,000 lb and our cars are less than half of that. With so little weight, it just doesn't take much to slow the car down, and the pads just never get hot enough. Plus that, bedding in the pads takes a long sequence of progressively harder stops to build up conditions gradually in order to drive off the volatile compounds. And with a light car, nothing's happening here either. I talked with Wilwood today and confirmed my suspicions. First of all it was recommend that I use lighter duty pads which also happen to bed in easier, (I was running BP-20s and will switch to BP-10s) because 'track-day' pads are spec'd for heavier cars generating lots of heat. For my car following many progressively harder stops, the tech suggested 100 to 50 mph stops hard enough where you could smell the brakes, allowing 10-15 SECONDS of cooling and then repeating a 100 to 50 mph stop with 10-15 sec cooling a second and then a third time. Take a shot of the caliper temperature with an IR thermometer and verify that you have 300+ degrees F, and then move the car to some place without touching the brakes, giving it 30 minutes to cool, and during this time periodically rolling the car forward to move the pads from where they were resting on the rotors, and then letting the car rest overnight. If you read what Carroll Smith wrote on this it's pretty much the same, and can be just as difficult to achieve as it sounds. . But, if you get this all together, you'll have brakes that'll stand the car on its nose (actually, just lock up all 4 wheels) with relatively modest force on the pedal, and the car will be a LOT more fun to drive. I'm struggling with figuring out where I can do this. There's a drag strip on the other side of town that may allow something like this,and I'm going to see if I can find a rural airport that'll allow me to make a few runs on a runway. I'm guessing that, after lots of preliminary, progressive stops, a single heavy pull down from 130 mph will do the trick. If you've glazed the pads, take 0.010” off each of the pads with 80 grit emory cloth and use maroon 3M pads on the rotors. I did this just to be sure I was working with good surfaces. *I found out that Wilwood recommends Coleman Machine in MI as a supplier of rotors and used them to produce front and rear rotors in cast iron for my S2K. In particular the fronts were cut from heavy duty blanks (not really what you would call "blanks") that could sink a lot of heat and lighter rotors for the rears that don't do such heavy duty. These have to go through much different dynamics than the steel rotors fitted to the 'standard' S2K. I also fitted radial mount 'Powerlite' calipers on both ends: driven by 0.625" front and 0.750" rear master cylinders pushing 1 3/8" front slave cylinders and 1" rear slave cylinders. If anyone is interested I'll post the full specs, which I did according to what Fred Puhn laid out in his (out of print) Brake Handbook. Puhn provides the math to figure out what to expect. On my car , with big heavy cast iron rotors weighing 26 lbs altogether, a stop from 90 to 20 mph raises the temperature of the rotors less than 200 degrees F.
Over the years, I've heard people complain about their Caterham's brakes being weak – and the usual advice is, “Don't worry about it. Just go around the corner faster.” However, this is not much comfort when you find yourself approaching the rear of a city bus faster than you intended. Now a brake system's job is to turn the car's kinetic energy (the car's weight times the square of it's speed) into heat, and it should do this quickly and with a modest amount of pressure on the brake pedal. The design of a complete braking system can be done with nothing more complicated than the Physics and Algebra one is supposed to have learned in high school and the dimension of all the bits involved; i.e., how the braking system will behave can be shown to result from the dimensions of the different brake system parts and the weight and dimensions of the car the system is fitted to*. So using paper and pencil, you can create a complete picture of how you'd like the car to be able to stop, and using that information, order what you need to accomplish that behavior. (I have a spreadsheet if anyone's interested.) However, one thing that cannot be gotten from the above and that greatly influences how the brakes will perform has to do with something called “bedding in the brakes”. If the brakes are not bedded in, it will be difficult for the driver to stop the car either easily or quickly – i.e., the brakes will be weak. This can be especially difficult to recognize and solve in a Se7en. When the friction material that's part of each brake pad assembly (friction material plus backing plate) is manufactured there are compounds contained within the pad friction material that make the friction material slippery – as manufactured, the pad doesn't create the friction it is supposed to when pressed against the rotor/drum. These compounds can be driven out of the pad by the driver progressively heating up the brakes in a series of stops done as a series of progressively higher speeds and greater pedal forces on the brake pedal. This progressively cycles the pads through hotter and hotter episodes, with cooling off periods in between all of which allows the compounds to vaporize into the atmosphere (and not deposit on the brake's rotors/drums). **See below, as copied directly from an old Wilwood web page. The goal here is gradually creating more and more heat in the pad in order to progressively drive the problem compounds out of the pad. As this occurs, i.e., while the driver is following the sequence of bedding in the pads, the pads will begin to generate more and more friction as more and more of the problem compounds leave the pad, and the pads will progressively generate more and more friction and hence more and more heat. The driver should be able to feel this as it takes place over the sequence of brake applications – it should become apparent that it takes less and less pressure to stop the car and that the sensitivity at the brake pedal becomes greater and greater. However – for cars that don't weigh much but have relatively big brakes, such as Se7ens and race/sports cars, it can be difficult to get the temperature of the pad up to a temperature high enough to drive the problem compounds out of the pad. In a 3,200 lb car running disks/rotors which together weigh 25 lbs, slowing quickly from 90 to 20 mph, will create a rise in temperature of 400 degrees F in the disks. This is enough heat to get the pads into the temperature range where they will generate their specified amount of friction and which should begin to drive off the problem compounds in the pads. The same setup in a 1,650 lb car (like a Se7en) will only create 200 degrees F in the same weight disks/rotors, which is generally not enough heat to get the pads to the temperature where they generate much friction, and not enough heat to drive out the problem compounds we're talking about. When I realized this by paying attention to the numbers I calculated (*Puhn), I began doing sequences of stops from 100 mph and using as much pressure as I could generate on the brake pedal, and leaving 1 to 2 minutes cool down between stops - not touching the brake pedal during that time. I also set the brake balance bar to bias the force as much as I could to the front brakes, planning to attend to bedding in the rear pads later. Even so, this only gets the disks/rotors to around 270 degrees. However this produced OK results. After a couple of such runs it required much less pressure on the brake pedal to slow the car, and even at lower speeds, the brakes were much more responsive and provided a much better feel. All of a sudden I had braking power where before there was very little. I expect to repeat this a number of times more to get the pads bedded, the problem being finding a place where I can get the car to 120 mph or so – without getting busted. - But don't start the process at high speed because the generation of heat needs to be gradual. I'll guess that in a light car one just has to be be a bit more aggressive on the pressure end of things. My own take is that the compounds you want to get rid of come off gradually, and if you try to do this all at once they will stay on the pad surface, and especially if you let the pads cool when they're pressed against the rotor/drum it will trap the compound in the pad and on the rotor/drum surface. If the bedding is done incorrectly it will require using emery cloth to take 0.010” off the pads and sanding the rotors/drums with Maroon 3M abrasive pads to provide a clean surface to start the process over again (use a 3' length from a roll of 3” wide 80 grit emery cloth clipped to a board to take the pads down 0.010” – this takes some work/patience). Getting this right can be hard. Carroll Smith wrote in Prepare to Win, page 81-82 that, even with a professional driver and having a race track at hand to set up the car, this can be difficult – to the point where Smith always went to races with a set of pads that had been bedded in correctly in his brief case, just in case. Notes: Before I went through all of this I changed from 9.75” front disks to 11” rotors, thinking that this would solve the problem – but if you follow the above, the larger rotors only made it worse. The larger diameter disks are even harder to get hot since they give the pad more leverage on the greater diameter rotor. Going to higher-friction, more aggressive pads seems like the fix here (which I also tried) but the benefits of such pads are gained by shortening the life of the rotors a lot, and these pads also need to be bedded in correctly as well. If you do the arithmetic the numbers show that the track-day grade Wilwood BP-20 pads are capable of standing the car on its nose (actually, just locking up the wheels), without shortening the life of the rotors like the next grade up. *”Brake Handbook” by Fred Puhn is the reference I used, which I recommend. There are likely a number of others that give . **Quote from http://www.wilwood.com (from an early web page): “Bedding is a “real conditions” heat cycle and the final step in preparing the pads for service. All pads, even OE stock replacement parts, will benefit from a proper bedding cycle. Bedding can be done either in the vehicle, or on a special bedding dyno that can realistically duplicate the torque loads, pressure, and temperature that will be realized in the vehicle. The bedding process is the final “heat cure” for the pads. This final bedding cure differs from an oven heat cure in such that the oven heat cure does not include the pressure, torque, and elevated surface temperatures that are necessary to properly condition the pad for service. New pads must be gradually brought up to temperature and then slowly cooled. If the pads are put into hard service right from the start, damage from fractures or accelerated deterioration due to extreme temperature variations between the surface and the body of the pad can occur. Once the brake system has been tested and determined safe to operate the vehicle, follow these steps for bedding of all pad materials. 1. Begin with a series of 8-10 light stops from approx. 30 MPH down to 15 MPH allowing 20-30 seconds for cooling between each stop. 2. Progress to series of 8-10 moderate stops from around 45 MPH down to 30 MPH allowing a 20-30 second cool down period between each stop. 3.Proceed with a series of 8-10 hard stops from 55-65 MPH down to 25 MPH allowing 20-30 seconds of cool down time between each stop. 4. Drive at a moderate cruising speed, with the least amount of brake contact possible, until most of the heat has dissipated from the brakes. Avoid sitting stopped with the brake pedal depressed to hold the car in place during this time. Park the vehicle and allow the brakes to cool to ambient air temperature. During the bedding process, a more positive feel from the brakes should develop. This is an indication that the bed in process is working. If any level of brake fade is observed during the hard stops, it may be an indication that the brakes have been more than adequately heated. Begin cooling the brakes with light driving and without brake contact immediately.
-------------------------------------------------------------------------------------------------------------------------------------- Just a heads up here that I have completed this little project and ---Over a thousand miles on the road, It hasn't flung me into the weeds by handling badly and none of my fabrications have broken. ---It does work as intended, and it does what I intended it to do even better than I'd hoped considering so much of the work depended on seat-of-the-pants decision making. Apologies for taking so long to get back to the topic but I wound up having to do other fixes along with the rear suspension and there were some other things that kept me away from the project. As I fiddle with the details I'll put together a wrap-up to tie the last bits together. Net: the car now shows just a bit of understeer and tossing the car into a corner the rear end is PLANTED just as solidly as the front. It worked.
