cytocycle
Everything posted by cytocycle
  1. I have a 2004 Ultralite with the AEM computer if you need me to look at anything. I can forward the latest manual Brian sent out it's huge now, which does include part numbers. Just PM me - Chris
  2. I have the backup of the now terminated Yahoo group for WCM Ultralite_USA Forum which has all the files, links and messages zipped up. If you would like to incorporate it in the new forum.
  3. WCM is no longer in business. They use to fix lotus 7 variants for track use in Texas and then decided to make their own. What they built were based on S2000 engine/transmission with WRX rear end and Coil overs . 1240lbs with 240hp. Prices started at 38k
  4. Mel, where are you located? I am in Scottsdale AZ and have WCM that's not running and the prior owner removed the front sway bar if you wanted to check it out.
  5. Bruce thanks again for putting this together, would love to get a copy, I will pm you my email. Thanks Chris
  6. Thanks I ordered a Tall shifter, and noticed the FAQ about greasing the factory shifter again. But mine is cut like 2-3" short.. and makes for very difficult quick shifting. I might order a stock arm if the taller shifter knob doesn't help. Mudhut - I wouldn't trade with you because mine is kinda brittle from being in Arizona. You just need to put some stickers that say "pussy Pedal fluid goes here" James Dean would be proud ;-)
  7. Thanks for posting up the door on the footwell, I hate removing that whole cowl because it's brittle here in AZ. I am going to see about doing something like that. What shifter is that? My S2000 Shifter is way to notchy because it's so short? Great build and attention to detail..
  8. Thanks for posting up I'm about to get mine running after 5 years of sitting, so this will be SO SO HELPFUL! Chris
  9. Thanks Bruce for the manual, I can already see some other items I have researched to be added. I'll get back to you with those summary items. Thanks Chris
  10. Bruce K, I have PM'd you my email and thanks for taking the time to build this. I hope to contribute while I work on mine and what I've found out also. Thanks Chris Roberts
