geoz3
Everything posted by geoz3
  1. Will do, as always thanks.
  2. Anybody close to Dacula Ga, that could check out a car for me ? Willing to pay for your time. It's not a 7, but a small fiat. 954-917-7683 Thanks George
  3. geoz3
    Fuse load
    The new bulbs are much higher wattage, according to item description of both bulbs. I guess I'll install the old lights and see if that is the problem. I don't want to increase the fuse size and take a chance of cooking the wire.
  4. geoz3
    Fuse load
    It did work with the original lights, don't know what pictures to post?
  5. geoz3
    Fuse load
    Installed new Harely rear taillights in my project, brake light and turn signals work, turn on the park or headlights 20 amp fuse blows. Is the proper way to measure load in Watts, or AMPS? The bulbs show both wats and amps, glass fuses show watts and amps.
  6. I'm on it
  7. Will do
  8. 6.5 or 7ish? LOL few things left to do.
  9. Ya it's a neat setup, I have now stored it, and went with the Brooklands.
  10. Neat windshield feature on the project.
  11. No problem, car runs cool, just asked the question.
  12. The guys who built the car back in the 80"s did a fantastic job, no bolts for most things that fasten, taped hole with machine screws. It's been fun putting it back together.
  13. I'm looking at venting from the heater outlet, to outside the car.
  14. No issues, I have not run it in heavy traffic yet, I just thought it may help to bleed off heat, run cool. LOL I'll test the effect on my next run.
  15. My project car has a under hood heater, small exchange box and 3 speed fan, I removed the in car directional box that switched from windshield defrost to footbox direction, I'm thinking of removing the under hood setup, but thought I could use it to dissipate engine water heat, and allow the car to run cooler, does it make sense?
  16. BTT
  17. Looking for a 4" in dash 4 wire TACH, direct to - side of coil. Prefer Back.
  18. Just saw some, no looking for the cloth shower cap type.
  19. Never seen them, can you post a picture?
  20. Finishing up the project, looking for 7" fog light covers.
  21. Again, thanks for all your help.
  22. The valve cover came on the motor, do you know if the standard gasket for the 2.0 will work on the cover or do I need a special gasket for ALUM cover?
