Biography
Mechanical Engineer, Retired from Coors Brewing Co. 2003, Own 2005 Caterham SV, Zetec SVT
Golden, Co
Interests
Hike, bike, ski and now my SV
Occupation
Retired ME
Se7en
2005 SV and Series 2 Lotus project
I went with the Burton "20mm breather elbow" that is press-fit into the block. I also ordered an oil fill cap with a breather outlet and a catch tank. Thankyou MV8 for the interesting information on the ford designed vent! And thankyou 7westfield for your caution regarding plugging the vent hole.
Never mind guys, I found everything that I need at Burton
I would like to vent my 1340 Cosworth crankcase into to catch tank. How do I connect to the block?
Thank you MV8!
Bill started following What fuel pump for a 1340 Cosworth?
What mechanical fuel pump is recommended for a 1340 Cosworth Ford engine with webers?
Where can I get a nose cone for a Series 2, Lotus 7?
Bill replied to Bill's topic in General Sevens Discussion
Yes, the headlight brackets align under the openings -
Incidently, about a week after I ordered the nose cone from MSC, I received a message from Chris at Redline that he had a S-2 nosecone that he could send to me! So if anyone is in the market for a nose cone, check with Chris and perhaps his product would need no modifications. -
Motorsports Composites nosecone: Thankyou Scott! I ordered a nose cone it from MSC. It fits quite well and the quality is good. I will need to make the following modifications: 1) cutout for the anti-sway bar 2) extend the skirt to fit the lower Dzus fasteners -
Thanks Scott! I will contact Motorsports composites. And thanks to all of you that contributed to this thread! -
Bad news: Just learned from Chris at Red Line that he is unable to furnish the nose S-2 nose cone that I ordered last April... so I am still looking for a nose cone. He said that the the Lotus S2 and S3 nose cones are the same except for the location of the Lotus emblem. The Caterham S3 nose cone is completely different. Lotusfan do you still have that nose cone....if not, any other leads? -
Cycle fenders were an option and this clamp was used for the lower cycle fender support -
Its a standard Triumph axel with Stegosaurus plate reinforcement. Nathen Down noted that welding on the plate often causes toe-out. Fortunately we discovered this problem with my axel before getting it cleaned up and powder coated. He is reworking it to get it back to neutral or slight toe-in. Incidentally, Nathen got 4th place in the Formula Ford 2024 SCCA National Championship Runoffs. (then 3rd and on the podium after one of the first 3 was disqualified) The race is now on YouTube if you want to check it out. -
Hi Guys, apologies for asking for help and then failing to follow up with your kind responses! My feeble excuse is that Chris at Redline said that he could furnish the series 2 nose cone that I need. That may have been a mistake as after 8 months he has not come through. In fairness, he has had trouble with his supplier and I am in no rush.....just taking my time and savoring this restoration. Here are some recent photos. 2025 Lotus2025 Lotus instrument panel.txt2024 Lotus wiring.txt instrument panel.txt
