carguy1315
Everything posted by carguy1315
Wanted Heater for Caterham or Lotus 7
carguy1315 replied to lotsats's topic in Parts For Sale / Wanted
I have an aluminum heater core, valve, plastic box and 2 speed blower from the Birkin I had. I took it out to reclaim the space. I'll post pix and dimensions if you're interested. -
Great deal on OEM Caterham KN style ET19, 16x7 wheels, 4x4.25" (4x108mm) bolt pattern, 4.75" Backspace, 2.5" center bore, excellent condition, with Super 7 security bolted center covers. $75 each or both for $125 (includes tool) plus shipping from 80524, carguy1315@hotmail.com
1998 Birkin S3, well sorted and major updates - SOLD
carguy1315 replied to carguy1315's topic in Cars For Sale
Car sold in December, arrived at new owner's house on Christmas Day. Thanks for your interest and help selling. -
Thanks to the forum and all who contacted me about this car. I had some fun times talking with those who called. Dennis is a great guy with some great car experience who will be a terrific addition to the list. I expect I’ll get another 7 someday, till then thanks and enjoy your cars and each other’s company. Best wishes, Jim Sent from my iPhone using Tapatalk -
I took my cracked windshield to an auto glass place and got a new non tinted one for $100 in a day or two. Sent from my iPhone using Tapatalk
Fabulous deal on one to three Caterham KN style ET19, 16x7 wheels, 4x4.25" (4x108mm) bolt pattern, 4.75" Backspace, 2.5" center bore, excellent condition, with security bolted center covers and special removal tool. KN Wheels Ltd., is the oldest alloy wheel manufacturer in the UK, and these are in excellent condition. Will trade for 15x7 or 15x8 Enkei RPF1s with 4x100 bolt pattern in similar condition. Best to email me direct: carguy1315@gmail.com Thanks!
Yes, it is still available for the right person/ home. Sent from my iPhone using Tapatalk -
My email is: carguy1315@gmail.com Sent from my iPhone using Tapatalk -
Try to PM me, I think that works. Or accept PMs to you. Everything listed is included, might be a few more things, everything I’ve collected for this car goes with it. Sent from my iPhone using Tapatalk -
Not yet Sent from my iPhone using Tapatalk -
Yellow Birkin S3 built in 1998, $25k obo, constantly updated, well sorted, easy to drive, RELIABLE, 2 liter Zetec, T9 5 speed transmission. Odometer now shows 64xx miles, it had 2164 when I took delivery on July 5th 2014. With slipping clutch (as described by previous owner), excessive rake and shocks set to maximum stiffness, I can see why nobody drove it much! With the clutch slave cylinder bled, rear shock pre-load and damping reduced it now rides comfortably and handles magnificently. Firmware update for ECU and tuning made the engine start instantly and run strong. Cold air intake brought more top end power and smoother running yet. Front facing intake rig now installed, rear facing rig included. Raceline water rail, Stewart Manufacturing electric water pump and controller, electric fan, East Coast Alternator 6 pound 2025 UltraMini 55 amp installed 2018. 2 Ford reprogrammed ECUs, 2 PCM and ignition modules included. Engine believed to be Series 3 because it has aluminum and steel sump, offset water pump, and horizontal oil filter. Fresh Ford plug wires, T9 standard ratio transmission flushed and fresh Redline gear lube 2020 Easily removable headlights with integral turn signals make aiming easier, includes new and used chrome buckets. Old style front turn signals and fender signals included. New, non-tinted windshield 2020 Spare windshield mounts could be used for a polycarbonate, shortened windshield. Wide track front end, installed Spring of 2019, has all new A-arms, ball joints, stub axles, steering arms, brake rotors and 4 piston Wilwood calipers, Wilwood .75” brake master cylinders, fender stays, working fenders and new front fenders. The new front end is quick and easy to align (street and track alignments now practical) and improves handling with 2” wider track than original. Jaz 15 position, single adjustable coil over shocks, corner weighted for 190 lb driver and half tank of gas. 15lb Braille battery 2 quart Accusump with electric pressure sensing valve, braided line in passenger compartment, aluminum rack mount for easy installation and removal in passenger seat area. Shortened fiberglass seats, reinforced driver's seat, OEM upholstered and light weight aluminum rear interior panels, 3 point belts installed, 5 or 6 point driver belts included, Hella battery cut off switch. Heater/fan unit, all interior panels, carpet, insulation, seat adjusting rails, and OEM external mirrors are included. Mini 7 four panel wink mirror with left and right side blind spot mirrors mitigates need for external mirrors Shown with 4 silver Enkei RPF1 wheels with 2015 195-50-15 Dunlop Direzza Sport ZII Star Spec tires. 2019 Bridgestone 195-50-15 RE71R tires on Black Enkei RPF1s with Black 948 Racing wheels (slightly wider front and rear track) Rear track variable from 52-56” (63" edge to edge) with included spacers and wheel selection. Quaife limited slip installed spring of 2017. Tall (broomstick test) 5 point track day roll bar has removable SFI padded Petty bar. The bikini top and doors work with both roll bars. Tonneau cover works with street and track roll bars sans Petty bar. For track events, I mount the Accusump rack where the passenger seat goes. OEM top works with the OEM roll bar now installed. All weather gear in excellent condition. Caterham clear and Birkin tinted wind wings. OEM 11 gallon tank. 3 piece trunk liner allows easy removal for changing roll bars, damper adjustment, rear axle maintenance. Driveshaft safety hoops. braided stainless DOT approved brake lines, braided fuel and oil pressure gauge and Accusump lines. Lightweight stainless steel Magnaflow side exit muffler (clears chassis dyno, saves 6 lbs.) and quieter, stock rear exit stainless steel muffler, heat shield and pipes. Lightweight fiberglass boot cover, spare tire rack, license plate light, some special tools, spare clutch, oil cooler included. Maintenance notes, Birkin build manual, Escort 4000pg factory pdf, T9 transmission manual, note book setup notes, measurements, Zetec and other info, bracket and panel templates, prototype rear compartment bottom panel.
Steve, Sorry, didn't see your request for measurements. Will be happy to measure them, not sure what you're looking for. The three wheels I have are all the same 16x7, 4x4.25" bolt pattern, they all have caps and security bolts. Can send pix of inner and outer surfaces. Best wishes, Jim
I have three in excellent condition, $100 each plus shipping. 970 567 4545 Thanks, Jim
I have five in excellent condition, with caps and security bolts. Prefer to sell all, but will sell singly. 970 567 4545 or PM me Thanks Jim
