cadillacjr
Everything posted by cadillacjr
  1. There is a lot of info at www.nasaproracing.com and you should check it out. The short version is that once you get a membership($40) all you need is a mechanically sound car and sa2000 or better rated helmet(no motorcycle helmets). The pre-tech is something you do yourself using a form from nasa, nothing too technical just belts, hoses, lug nuts etc. followed by a quick once over by the tech guys at the track. The cost for an event seems to run about $150 a day, this gets you 4 20 minute track sessions. If you've never run with NASA before they start you in HPDE1(novice) where you are assigned an instructor to ride with you. I don't know your experince level but if you are just getting started this is a great place to learn and if you are more experienced your instructor will confirm this and sign you off for a more advanced run group. I hope you come out, it's always great to see another se7en at the track.
  2. Mid Ohio is also my local track(90 miles away). Just did last weekend there with NASA OH/IN. They have racing but also HPDE (high performance driver ed) separated into 4 different classes for novice through advanced drivers. There are 2 more NASA events at Mid Ohio in July and August plus the Nationals in September.
